EWS on 3750
balajitvk
Level 4
Level 4
I have 3750-12S switches and want to do EWS with that. Can i use this in place of U-PEs. If so what ios version is required????
Rgs
pkhatri
Level 11
Level 11
You need the 3750 Metro Series switches for the support of MPLS, EoMPLS and H-VPLS.
Hope that helps - pls rate the post if it does.
Paresh
Could u tell me in HardWare wise whether 3750 metro swtiches are different from 3750-12S. If not, can we get required functionality thro, SW upgradation????
Rgs,
Nopes Sorry Doubt if you can do with a software upgrade. A browse through FN will show you that both have different software. So I dont think the software will be interoperable.
raj.panchal
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(25)SEB, RELEASE SOFTWARE (fc1)
Switch Ports Model SW Version SW Image
* 1 12 WS-C3750G-12S 12.2(25)SEB C3750-IPSERVICESK9-M
Supports EWS
U can upgrade the box ..
Pls rate the post if it helps
Thanks and Regards
Raj Panchal
