Hi Ciscomates!
I'm trying to set up a PPPoE server in a cisco 7606 to connect PPPoE clients into service instances but I don't know if it's possible.
I have a CISCO7606-S SUP7203B + SIP-400 + SPA-5X1GE-V2 with IOS 12.2(33)SRC6
That is part of my config:
interface Loopback1
ip address 1.1.1.1 255.255.255.255
bba-group pppoe test
virtual-template 13
interface GigabitEthernet3/3/4
no ip address
negotiation auto
service instance 6 ethernet
encapsulation dot1q 21
rewrite ingress tag pop 1 symmetric
bridge-domain 21 split-horizon
service instance 7 ethernet
encapsulation dot1q 22
interface Virtual-Template13
ip unnumbered Loopback1
no ip redirects
no ip unreachables
ip accounting access-violations
ppp authentication pap
I can't configure "pppoe enable group test" to enable pppoe server under service instance and if I configure it under physical interface doesn't work.
If I set another interface for bridge traffic to another PPPoE server it's works, like this,
interface GigabitEthernet3/3/3
no ip address
negotiation auto
encapsulation dot1q 7
bridge-domain 21
But I would like to finish PPPoE sessions in the same router that service instance are.
Some ideas?
Regards.
