PPPoE SESSION ON CISCO 7206 ROUTER
bassomoserge
HI
Dear all
I have a problem of    understanting the concept of LINE CARD on a router. On our network we   are running C7203 and C7209 routers. The maximum sessions are :
• Maximum number of IP and PPPoE subscriber sessions supported per line card is 16000.
I want to know if we buy additionnal card the number of PPPoE subscriber sessions supported will be multiplied by 2.
Here  is my problem. We have have connected a DSLAM of  862 subscribers  behind a C7203 router. We translate private ip addresses  with a pool of  30 public ip addresses and we have a CPU usage of 72%.
We   have 5 others DSLAMs connected to a switch . These 5 DSLAMs support   4500 subscribers. Is it possible by buying 3 additionnal line cards on   my C7609 to have 64 000 sessions.
Also when CISCO says
does it means that in my case i have to connect each DSLAM on one particular line card?
Is   it possible to connect the cable from my switch on a C7609 router  (with  3 additionnal line cards ) and have a maximums PPPoE subscribers   sessions of 64000
Thx
yashfaqu
I have already replied in MPLS Section.
