Rate limit- Policy-map policing on ME3400
gregwoodson
I am trying to rate limit (both input and output) a port on an ME3400 to 1.5 Mb.  I have tried the old CAS commands:
rate-limit input 1500000 256000 256000 conform-action transmit exceed-action drop
rate-limit output 1500000 256000 256000 conform-action transmit exceed-action drop
This didnt work.
policy-map ratelimit-1.5Mb
class class-default
    police 1500000    conform-action transmit     exceed-action drop
service-policy input ratelimit-1.5Mb
This works for input- but not output.
Same with this:
class class-default
     police rate 1500000
      exceed-action drop
What is the correct way to do this?
Greg
Jason M.
Hello Greg,
If "service-policy output **** " doesn't work for policing class default try marking the traffic coming into the switch on the uplink they policing that dscp value.
class-map match-all MATCH-DSCP
 match ip dscp cs1
policy-map UPLINK
 class class-default
  set ip dscp cs1
Then under your output policy (different from input policy) use "class MATCH-DSCP" and set your policer. I suggest you add "queue-limit 544" to the output policy also to prevent output drops from queue congestion.
Output policy's can be tricky sometimes. I've had to nestle three policies deep to shape class default on a 3800. Manipulation of marked traffic seems to be easier.
