Rewrite command in ASR901
cheewai
I wonder how to change an ingress untag frame to different Vlan tag on the egress port. Which mean the
source packets is untag, then when it go into the egress instance it will become VLAN 100.  And when the VLAN 100
reply it can be goes back to the original source instance which is the untag frame.
I have tried to ping from untag instance to another untag instance on the same bridge-domain within the same ASR901 and it
susccessful ping test.
Can anyone knwo how to use rewrite command to change the VLAN tag frame?
Tested Scenario - Done
PC (Untag) --- ASR 901 --- PC (Untag)
Need to be test scenario
PC (Untag) ---- ASR ----VLAN 100 (PC)
Regrads
0 Replies 0
