[solved]VPLS can not activate
yinan yang
Hello guys,
I meet a pretty strange problem. I use ME36600X to test the vpls. And i cant activate the vfi.It said "Maximum number of VFIs 0 have been configured."
And the other ME3600x have no problem at all.
Someone know where is the problem?
The two ME3600x have the exactlly same license and IOS version.
thanks!
3600-1(config)#l2 vfi test autodiscovery
Cisco IOS Software, ME360x Software (ME360x-UNIVERSALK9-M), Version 15.2(2)S1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 22-May-12 21:21 by prod_rel_team
ROM: Bootstrap program is WHALES boot loader
BOOTLDR: ME360x Boot Loader (ME360X-HBOOT-M), Version 12.2 [sourdutt-loader_release_ledfix 100]
3k1.me.rd uptime is 1 hour, 48 minutes
System restarted at 16:05:39 UTC Thu Aug 23 2012
System image file is "flash:/me360x-universalk9-mz.152-2.S1/me360x-universalk9-mz.152-2.S1.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: AdvancedMetroIPAccess
License Type: Permanent
Next reload license Level: AdvancedMetroIPAccess
cisco ME-3600X-24FS-M (PowerPC8572) processor (revision A0) with 1015808K/32760K bytes of memory.
Processor board ID FOC1615V1AY
Last reset from power-on
2 Virtual Ethernet interfaces
25 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
1536K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : F4:EA:67:B2:C1:80
Motherboard assembly number     :
Motherboard serial number       :
Model revision number           : A0
Motherboard revision number     : B0
Model number                    : ME-3600X-24FS-M
System serial number            :
Top Assembly Part Number        : 800-32951-01
Top Assembly Revision Number    : B0
Version ID                      : V01
CLEI Code Number                :
Configuration register is 0xF
CSCO11777723
Cisco Bug CSCua05375, just change the sdm config to "default"
