Two Router share one link (Metro Ethernet)
raymond.ho
We setup a link on remote site to connect to Head office . Now,it require fault tolerant. If I have another router on remote site, can it share the one link at the same time?
sbilgi
Level 5
Level 5
This is not possible. Instead you can use ppp multilink to bundle different serial links and also provide load balance and fault tolerance to one remote site. Here's a link on PPP multilink:
http://www.cisco.com/warp/public/471/multilink_bundles.html
If this is Metro-Ethernet you can do Ether-Channel.
Cisco on-board Eth ports do not support ether-channel however their NM modules and switches do.
Check with your Service Provider if they support Ether-Channel.
