7600: local switching of packets between interfaces and EoMPLS
petrowic
Hello, my name is Petr Akimov employed as engineer by ZAO KORTEK - Russia, Moscow. I had success configuring EoMPLS in the following method (VLAN mode):
7600-1 (equipped with WS-SUP720-3BXL and WS-X6724-SFP):
interface Loopback0
ip address 10.14.40.2 255.255.255.255
interface GigabitEthernet6/2.998
encapsulation dot1Q 998
tag-switching ip
mpls l2transport route 10.14.40.3 66
interface GigabitEthernet6/1
description mpls1
mtu 9216
ip address 10.14.54.249 255.255.255.252
ip ospf network point-to-point
tag-switching ip
7600-2(equipped with WS-SUP720-3BXL and WS-X6724-SFP):
interface Loopback0
ip address 10.14.40.3 255.255.255.255
tag-switching ip
mpls l2transport route 10.14.40.2 66
description mpls1
mtu 9216
ip address 10.14.54.250 255.255.255.252
tag-switching ip
network topology is:
3550-1----7600-1----7600-2---3550-3
3550-2
There is a problem:
In this network topology I have not found the way to combine EoMPLS as aforesaid and the transparent local switching of packets between the same interface. Is it possible to switch between 3550-1 and 3550-2 through 7600-1?
Best regards,
Petr Akimov
Engineer
petrowic
----------3550-2
petrowic
http://www.cisco.com/en/US/partner/products/hw/routers/ps368/products_configuration_guide_chapter09186a00801e5c06.html#wp1108390
"EoMPLS based on PFC3BXL does not perform any layer-2 look up to determine if the destination MAC address resides on the local or remote segment and does not perform any layer-2 address learning (as traditional LAN bridging does). This functionality (local switching or hair pinning) is available only when using OSM/FlexWAN-based modules as uplinks."
Dear experts, is there any workaround? OSM/FlexWAN-based modules are too expensive!
