10-23-2007 04:07 PM
Having problems retrieving server list on Steam for Team Fortress 2. The ports that need opening are:
* UDP 27000 to 27020 inclusive
* TCP 27020 to 27050 inclusive
I've added those to my access-list 102, but still can't retrieve the server list. Not sure what I am missing.
10-29-2007 03:37 PM
Make sure that IPS services are not enabled on your router because of the way the packets are handled by Team Fortress the IPS may get the impression of a DoS attack and may block the packets. Check the router logs if it is discarding the packets.
10-29-2007 11:11 PM
Says I do not even have an IOS image that supports IPS.
03-26-2008 03:46 AM
Well you have allowed
access-list 102 permit udp any any eq 27020
If the ports is what you say it should be
access-list 102 permit udp any any range 27000 27020
AFAIK
