a problem about discarding data packet on Cisco router 805?
guominquan
hi,all
A router 805 that is regarded as CE to MPLS/VPN. the router only support 512K bandwidth on its Interface S0,and the MPLS line bandwidth to CE is 256K,It always discards data packets when I ping to peer after connected the router to MPLS network. but I replaced the router 805 with cisco 1721,everything is going well. why?
configs are as follows:
hostname xxx
interface FastEthernet0
ip address 172.28.169.1 255.255.255.224
speed auto
interface Serial0
description MCI MPLS network connect to HK office
bandwidth 256
ip address 192.168.63.142 255.255.255.252
router rip
version 2
network 172.28.0.0
network 192.168.63.0
no auto-summary
ip classless
no ip http server
line vty 0 4
password cisco
login
ntp server 172.28.4.1
mohammedmahmoud
Level 11
Level 11
This issue is not related to MPLS (as your CE router is not MPLS aware at all), can you please post sh interface serial 0, and can you please clarify if this peer is a directly connected peer (the PE router infront of your CE) or another remote router through the MPLS cloud.
HTH,
Mohammed Mahmoud.
