Need help with NAT VRF Aware
dankennedy
Hi. I am having some problems with VRF aware NAT. I have followed the Cisco documentation, but i'm still having problems with dynamic nat.
The scenerio is i have a VRF called CUST1 which i can NAT if i use static vrf NAT, but not dynamic. The configuration is as follows
ip nat pool CUSTA_POOL 192.168.10.17 192.168.10.17 netmask 255.255.255.0
ip nat source list CUSTA_NAT pool CUSTA_POOL vrf CUSTA overload
ip route vrf CUSTA 0.0.0.0 0.0.0.0 FastEthernet0/0 217.20.23.17
ip access-list standard CUSTA_NAT
permit 172.16.0.0 0.0.255.255 log
interface FastEthernet0/0
description "OUTSIDE INT"
ip vrf forwarding SHARED_INT
ip address 192.168.10.1 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex full
interface Ethernet2/0.1
encapsulation dot1Q 10
ip vrf forwarding CUSTA
ip address 172.16.1.10 255.255.255.252
ip nat inside
When using the configuration as above i can see that NAT does not take place as i can see the real address (172.16.1.9) on the next hop. If i use a static NAT statement like...
ip nat inside source static 172.16.1.9 192.168.10.17 vrf CUSTA
It will succesfully NAT. Any help with this would be much appreciated.
Dan.
mheusing
With the configuration above there were some restrictions depending on platform and IOS version - including VRF to VRF NAT, if I remember correctly.
Did you have a look at the NAT virtual interface at
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a008041d91a.html
This should be solving your issue. The document will give you an example for static as well as dynamic NAT. All you need to do, is to adjust names and addresses, I guess.
Hope this helps!
Regards, Martin
This did not solve my issue. I do have the an IOS supporting all required features. Any other ideas?
Dan.
Hi Dan, you config in this post looks like for a NAT between a VRF and global interface, going by the "ip route".
Please do refer to which Cisco document you have been suing for the same.
If its a NAT between VRF and a Global interface, I have replied to it in the other thread. If its VRF to VRF then Martin has given the right link.
HTH-Cheers,
Swaroop
