ADSL configuration for cisco 2811 ADSL router
arumugasamy
Dear Netpros,
Find below the configuration script for the adsl HUAWEI route got from local isp.
sysname 17580482
cpu-usage cycle 1min
DNS resolve
DNS server 117.17.233.49
DNS server117.16.233.101
DNS server 183.184.97.197
DNS server 183.186.97.202
web set-package force flash:/http.zip
radius scheme system
domain system
interface Aux0
async mode flow
shutdown
interface Ethernet0/0
ip address 70.69.103.54 255.255.255.248
interface Serial0/0
clock DTECLK1
link-protocol ppp
shutdown
ip address dhcp-alloc
interface Atm1/0
loadbandwidth 2048
interface Atm1/0.1
pvc 8/35
map bridge Virtual-Ethernet1
interface Atm1/0.2
pvc 7/35
map bridge Virtual-Ethernet2
interface Virtual-Ethernet1
description INET-SERVICE
ip address 70.69.105.21 255.255.255.252
interface NULL0
FTP server enable
ip route-static 0.0.0.0 0.0.0.0 70.69.105.22 preference 60
snmp-agent local-engineid 000007DB7F0000010000233D
snmp-agent community read cisco
snmp-agent community write cisco
snmp-agent sys-info version all
snmp-agent target-host trap address udp-domain 102.3.6.104 params securityname cisco v3
snmp-agent trap source Virtual-Ethernet2
user-interface con 0
authentication-mode scheme
user-interface aux 0
user-interface vty 0 4
Brief:
I tried to configure the cisco router 2811 replacing the HUAWEI router with the below config details i usally do for the adsl connection usign SDM GUI.
The PVC 8/35 and encap pppoAMUX and username and password.
But the result is atm up but the virtual-access 2 is down. LCP ReQ some message appear.
Finally the ISP informed us that they setup would not support Cisco routers and adviced the customer go for fixed ip adsl service that support the config i used (PVC,PPPOAMUX). ISP gave the customer managed adsl service that not work with cisco router. I do not believe it and i believe i forget the cmds to configure.
So i came to the Form for your help.
Please advice me how can i support the customer?.
Customer adviced by ISP for the leased line service with fixed IP ADDRESSES.
swami
0 Replies 0
