ASR1006 - %CMCC-3-PLIM_STATUS: SIP1: cmcc: A PLIM driver informational error TXSPI0
Gabriel Farias
Hello time,
I have a critical issue, I have equipment LER, were recently installed new SPA-V2 cards after this event are recorded in the logging messages:
May 13 10:59:12: %CMCC-3-PLIM_STATUS: SIP1: cmcc: A PLIM driver informational error TXSPI0 Frame Error, block 17 count 3
May 13 10:59:22: %CMCC-3-PLIM_STATUS: SIP1: cmcc: A PLIM driver informational error TXSPI0 Frame Error, block 17 count 1
May 13 10:59:32: %CMCC-3-PLIM_STATUS: SIP1: cmcc: A PLIM driver informational error TXSPI0 Frame Error, block 17 count 1
May 13 11:00:02: %CMCC-3-PLIM_STATUS: SIP1: cmcc: A PLIM driver informational error TXSPI0 Frame Error, block 17 count 1
May 13 11:00:12: %CMCC-3-PLIM_STATUS: SIP1: cmcc: A PLIM driver informational error TXSPI0 Frame Error, block 17 count 1
May 13 11:00:32: %CMCC-3-PLIM_STATUS: SIP1: cmcc: A PLIM driver informational error TXSPI0 Frame Error, block 17 count 1
May 13 11:00:42: %CMCC-3-PLIM_STATUS: SIP1: cmcc: A PLIM driver informational error TXSPI0 Frame Error, block 17 count 1
May 13 11:00:52: %CMCC-3-PLIM_STATUS: SIP1: cmcc: A PLIM driver informational error TXSPI0 Frame Error, block 17 count 1
May 13 11:01:12: %CMCC-3-PLIM_STATUS: SIP1: cmcc: A PLIM driver informational error TXSPI0 Frame Error, block 17 count 3
After an average of presented, the output traffic established by SPA-2X1GE-V2 stop and protocols established through the GigabitEthernet intefaces go down
#show platform
Chassis type: ASR1006
Slot Type State Insert time (ago)
0 ASR1000-SIP10 ok 2d17h
0/0 SPA-8XCHT1/E1-V2 ok 2d01h
0/1 SPA-8XCHT1/E1-V2 ok 2d01h
0/2 SPA-8XCHT1/E1-V2 ok 2d01h
0/3 SPA-8XCHT1/E1-V2 ok 2d01h
1 ASR1000-SIP10 ok 2d17h
1/0 SPA-2X1GE-V2 ok 00:32:18
1/1 SPA-8XCHT1/E1-V2 ok 00:32:13
1/2 SPA-8XCHT1/E1-V2 ok 00:32:09
1/3 SPA-8XCHT1/E1-V2 ok 00:31:58
2 ASR1000-SIP10 ok 2d17h
2/0 SPA-8XCHT1/E1-V2 ok 2d01h
2/1 SPA-8XCHT1/E1-V2 ok 2d01h
2/2 SPA-8XCHT1/E1-V2 ok 2d01h
2/3 SPA-8XCHT1/E1-V2 ok 2d01h
R0 ASR1000-RP1 ok, active 2d17h
R1 ASR1000-RP1 ok, standby 2d17h
F0 ASR1000-ESP10 ok, standby 2d17h
F1 ASR1000-ESP10 ok, active 2d17h
P0 ASR1013/06-PWR-AC ok 2d17h
P1 ASR1013/06-PWR-AC ok 2d17h
Slot CPLD Version Firmware Version
0 09111601 15.4(2r)S
1 09111601 15.4(2r)S
2 09111601 15.4(2r)S
R0 11060317 15.4(2r)S
R1 07062111 15.4(2r)S
F0 09111601 15.4(2r)S
F1 07091401 15.4(2r)S
#show facility-alarm status
System Totals Critical: 0 Major: 0 Minor: 0
Source Severity Description [Index]
#show hw-module subslot all oir
Module Model Operational Status
subslot 0/0 SPA-8XCHT1/E1-V2 ok
subslot 0/1 SPA-8XCHT1/E1-V2 ok
subslot 0/2 SPA-8XCHT1/E1-V2 ok
subslot 0/3 SPA-8XCHT1/E1-V2 ok
subslot 1/0 SPA-2X1GE-V2 ok
subslot 1/1 SPA-8XCHT1/E1-V2 ok
subslot 1/2 SPA-8XCHT1/E1-V2 ok
subslot 1/3 SPA-8XCHT1/E1-V2 ok
subslot 2/0 SPA-8XCHT1/E1-V2 ok
subslot 2/1 SPA-8XCHT1/E1-V2 ok
subslot 2/2 SPA-8XCHT1/E1-V2 ok
subslot 2/3 SPA-8XCHT1/E1-V2 ok
Philip D'Ath
I can't figure out what software version you are using.  3.16.x?  What version is it?
The CMCC PLIM errors are treated as transient or hardware errors on the SPA or the SIP card. In order to resolve this issue, perform a jack out and jack in of the SPA card.
If this doesnt fix teh problem, you will have to try replacing the SPA card. If the issue is still not fixed, then you may think towards SIP card (though it doesnt look like its SIP issue).
Hope this helps.
Vinit
--Vinit
Hello members,
The question was resolvisa the problems was the SPA 0 position slot ASR1000-sip10 plate (JAE1739076K) now slot 2, this problem affected the SPA-2X1GE-V2, with the unique uplink interfaces for backbone.
The palliative solution was changing the position of the SPA, to be made the RMA SIP, will follow the final configuration of the plates.
RT113MCE#show platform
0 ASR1000-SIP10 ok 5d23h
0/0 SPA-2X1GE-V2 ok 5d23h
0/1 SPA-8XCHT1/E1-V2 ok 5d23h
0/2 SPA-8XCHT1/E1-V2 ok 5d23h
0/3 SPA-8XCHT1/E1-V2 ok 5d23h
1 ASR1000-SIP10 ok 5d22h
1/0 SPA-8XCHT1/E1-V2 ok 5d22h
1/1 SPA-8XCHT1/E1-V2 ok 5d22h
1/2 SPA-8XCHT1/E1-V2 ok 5d22h
1/3 SPA-8XCHT1/E1-V2 ok 5d22h
2 ASR1000-SIP10 ok 5d22h
2/0 SPA-8XCHT1/E1-V2 out of service 5d22h
2/1 SPA-8XCHT1/E1-V2 ok 5d22h
2/2 SPA-8XCHT1/E1-V2 ok 5d22h
2/3 SPA-8XCHT1/E1-V2 ok 5d22h
R0 ASR1000-RP1 ok, active 5d23h
R1 ASR1000-RP1 ok, standby 5d23h
F0 ASR1000-ESP10 ok, active 5d23h
F1 ASR1000-ESP10 ok, standby 5d23h
P0 ASR1013/06-PWR-AC ok 5d23h
P1 ASR1013/06-PWR-AC ok 5d23h
