ASR920 MPLS
Hello, I am developing a project with ASR920 with the advanced metro ip access license. We want to use the equipment to make an MPLS network. My question is, can ASR920 perform both LER and LSR functions at the same time or I need two ASR920?
Short answer to your question is: yes you can.
Then of course you haven't talked about what services you need to run on your network (L3VPN, L2PVN etc..)
The following is pretty clear and exahustive per-service description of what the license you're looking for can do, I would personally opt in for the Advanced version :
https://www.cisco.com/c/en/us/products/collateral/routers/asr-920-series-aggregation-services-router/datasheet-c78-732079.html
