AToM Frame Relay over MPLS
tsabry
Is it possible to have multipoint topologies with FRoMPLS? In other words, if I'm receiving some Frame Relay PVCs on one physical interface on a PE, can I transport some of them to one remote PE and others to another remote PE? Or do I need to have separate physical interfaces to talk to different remote PEs?
Tarek
Harold Ritter
On the PE router, you can indeed take each one of the DLCIs from a same physical interface and connect them to a different egress PE.
Hope this helps,
Well that seems to precisely address my question. Thank you!
