AToM not passing traffic even with vc up.
adecisco
Dear Community member,
I need you to assist to suggest possible reason for the following issues in the attached diagram.
1. IGP is OSPF
2. mpls is enable across the network.
3. reachability is confirm between the two end cisco router where AToM config is turn on.
4. The environment is mixture of cisco router and mikrotic as depicted in the diagram.
The following are the show command I got but could not find what may be the possible issues with the setup...
RT_ATOM_1#ping mpls pseudowire 172.27.11.254 10 reply mode router-alert
Sending 5, 100-byte MPLS Echos to 172.27.11.254,
     timeout is 2 seconds, send interval is 0 msec:
Codes: '!' - success, 'Q' - request not sent, '.' - timeout,
  'L' - labeled output interface, 'B' - unlabeled output interface,
  'D' - DS Map mismatch, 'F' - no FEC mapping, 'f' - FEC mismatch,
  'M' - malformed request, 'm' - unsupported tlvs, 'N' - no label entry,
  'P' - no rx intf label prot, 'p' - premature termination of LSP,
  'R' - transit router, 'I' - unknown upstream index,
  'X' - unknown return code, 'x' - return code 0
*Jul  9 10:22:23.227: ATOM-disposition: incoming tag 117441733 in Fa0/0, size 108, packet dropped, Inband Control packet dropped.
*Jul  9 10:22:25.103: ATOM-disposition: incoming tag 117441733 in Fa0/0, size 108, packet dropped, Inband Control packet dropped.
*Jul  9 10:22:27.071: ATOM-disposition: incoming tag 117441733 in Fa0/0, size 108, packet dropped, Inband Control packet dropped.
*Jul  9 10:22:28.939: ATOM-disposition: incoming tag 117441733 in Fa0/0, size 108, packet dropped, Inband Control packet dropped.
*Jul  9 10:22:30.927: ATOM-disposition: incoming tag 117441733 in Fa0/0, size 108, packet dropped, Inband Control packet dropped.
Success rate is 0 percent (0/5)
RT_ATOM_1#sho mpls l2transport vc 10 detail
Local interface: Fa8 up, line protocol up, Ethernet up
  Destination address: 172.27.11.254, VC ID: 10, VC status: up
    Output interface: Gi0, imposed label stack {142090 1221}
    Preferred path: not configured
    Default path: active
    Next hop: 172.27.1.1
  Create time: 00:25:32, last status change time: 00:19:08
  Signaling protocol: LDP, peer 172.27.11.254:0 up
    Targeted Hello: 172.27.11.252(LDP Id) -> 172.27.11.254
    Status TLV support (local/remote)   : enabled/not supported
      Label/status state machine        : established, LruRru
      Last local dataplane   status rcvd: no fault
      Last local SSS circuit status rcvd: no fault
      Last local SSS circuit status sent: no fault
      Last local  LDP TLV    status sent: no fault
      Last remote LDP TLV    status rcvd: not sent
    MPLS VC labels: local 1223, remote 1221
    Group ID: local 0, remote 0
    MTU: local 1500, remote 1500
    Remote interface description:
  Sequencing: receive disabled, send disabled
  VC statistics:
    packet totals: receive 0, send 4318
    byte totals:   receive 0, send 474880
    packet drops:  receive 0, seq error 0, send 0
RT_ATOM_1#sho mpls l2transport binding
  Destination Address: 172.27.11.254,  VC ID: 10
    Local Label:  1223
        Cbit: 1,    VC Type: Ethernet,    GroupID: 0
        MTU: 1500,   Interface Desc: n/a
        VCCV: CC Type: CW [1], RA [2]
              CV Type: LSPV [2]
    Remote Label: 1221
              CV Type: LSPV [2]
RT_ATOM_1#sho mpls forwarding-table | i l2
1223       No Label   l2ckt(10)        0             Fa8        point2point
RT_ATOM_2#sho mpls l2transport vc 10 detail
Local interface: Fa0/1 up, line protocol up, Ethernet up
  Destination address: 172.27.11.252, VC ID: 10, VC status: up
    Next hop: 172.27.14.25
    Output interface: Fa0/0, imposed label stack {550 1223}
  Create time: 00:11:53, last status change time: 00:08:18
  Signaling protocol: LDP, peer 172.27.11.252:0 up
    MPLS VC labels: local 1221, remote 1223
  VC statistics:
    packet totals: receive 2446, send 1553
    byte totals:   receive 224196, send 213523
    packet drops:  receive 15, seq error 0, send 0
RT_ATOM_1#sho mpls l2transport binding 10
    Local Label:  1223
              CV Type: LSPV [2]
    Remote Label: 1221
              CV Type: LSPV [2]
yourname#
RT_ATOM_2#sho mpls l2transport binding 10
  Destination Address: 172.27.11.252,  VC ID: 10
    Local Label:  1221
              CV Type: LSPV [2]
    Remote Label: 1223
              CV Type: LSPV [2]
Looking at output of command sho mpls l2transport vc 10 detail it can be observed that ATOM_2 is sending and receiving packet but that is not the case for ATOM_1
What could be wrong with this scenario?
Your input will be appreciated.
Thank you,
9 Replies 9
bhnegi
Looks like you have the attachment circuit on RT_ATOM_1  on a ether switch module(FA8).
Local interface: Fa8 up, line protocol up, Ethernet up<<<<<<<<
Can you try the xconnect on a onboard routed port?
What kind of router is RT_ATOM_1. Can you please send me "show ver" and "show run" info.
Best Regards,
Bheem
Hi Bheem,
The interface is onboard. Here are the show version of each of them.
But I will want you to explain further what you mean by attachment circuits and the effect of ether switch on this solution. It may give a good clue to the possible problem being faced.
sho version
Cisco IOS Software, C890 Software (C890-UNIVERSALK9-M), Version 15.2(4)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 26-Feb-13 13:19 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB3, RELEASE SOFTWARE (fc1)
RT_ATOM_1 uptime is 1 day, 1 hour, 0 minutes
System image file is "flash:c890-universalk9-mz.152-4.M3.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 891 (MPC8300) processor (revision 1.0) with 498688K/25600K bytes of memory.
Processor board ID FCZ1721C27P
9 FastEthernet interfaces
1 Gigabit Ethernet interface
1 Serial interface
1 terminal line
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
247464K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO891-K9           FCZ1721C27P
License Information for 'c890'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
sho run
Building configuration...
Current configuration : 5597 bytes
! Last configuration change at 12:31:06 UTC Wed Jul 9 2014 by admin
version 15.2
hostname RT_ATOM_1
boot-start-marker
boot-end-marker
logging buffered 102400
logging console informational
no aaa new-model
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
license udi pid CISCO891-K9 sn FCZ1721C27P
username admin privilege 15 password 0 cisco
redundancy
pseudowire-class MPLS
 encapsulation mpls
interface Loopback0
 ip address 172.27.11.252 255.255.255.255
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
interface FastEthernet5
 no ip address
interface FastEthernet6
 no ip address
interface FastEthernet7
 no ip address
interface FastEthernet8
 no ip address
 duplex auto
 speed auto
 xconnect 172.27.11.254 10 pw-class MPLS
interface GigabitEthernet0
description connection to mikrotic router
 mtu 1600
 ip address 172.27.1.2 255.255.255.248
 ip ospf mtu-ignore
 duplex auto
 speed auto
 mpls ip
interface Vlan1
 description $ETH_LAN$
 ip address 10.10.10.1 255.255.255.248
 ip tcp adjust-mss 1452
 shutdown
interface Async1
 no ip address
 encapsulation slip
router ospf 101
 network 0.0.0.0 255.255.255.255 area 1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
mgcp profile default
end
RT_ATOM_2 sho ver
sho ver
Cisco IOS Software, 1841 Software (C1841-SPSERVICESK9-M), Version 12.4(15)T14, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 17-Aug-10 05:25 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
RT_ATOM_2 uptime is 25 minutes
System image file is "flash:c1841-spservicesk9-mz.124-15.T14.bin"
export@cisco.com.
Cisco 1841 (revision 7.0) with 116736K/14336K bytes of memory.
Processor board ID FCZ111922K9
2 FastEthernet interfaces
1 Serial(sync/async) interface
2 Low-speed serial(sync/async) interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
RT_ATOM_2#
RT_ATOM_2#sho run
Current configuration : 1409 bytes
version 12.4
service password-encryption
hostname RT_ATOM_2
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret 5 $1$HEDc$NCqFZHFqsKMwYwU2dpQcD1
no aaa new-model
dot11 syslog
ip cef
 encapsulation mpls
interface Loopback0
 ip address 172.27.11.254 255.255.255.255
interface FastEthernet0/0
 mtu 1600
 ip address 172.27.14.26 255.255.255.252
 ip ospf mtu-ignore
 speed 100
 full-duplex
 mpls ip
interface FastEthernet0/1
 no ip address
 duplex auto
 speed auto
 xconnect 172.27.11.252 10 pw-class MPLS
interface Serial0/0/0
 no ip address
 shutdown
 clock rate 2000000
interface Serial0/1/0
 no ip address
 shutdown
 clock rate 125000
interface Serial0/1/1
 no ip address
 shutdown
 clock rate 125000
router ospf 101
 router-id 172.17.11.254
 log-adjacency-changes
 redistribute connected subnets
 network 0.0.0.0 255.255.255.255 area 0
ip http server
no ip http secure-server
mpls ldp router-id Loopback0 force
control-plane
Attachment circuit is where xconnect is configured. In your case F8.
I don't have access to a 891 but is FA8 a layer3 port? Are you able to assign an ip address on it?
If not you cannot apply xconnect on a layer2 port.
You can try configuring the xconnect on a interface vlan though.
conf t
no xconnect 172.27.11.254 10 pw-class MPLS
switchport access vlan X
interface vlan x
no shut
Best Regards,
Bheem
Fa8 is a layer 3 interface.
Can you configure FA7 as an access port in vlan x and create an interface vlan x with xconnect on it and see if you are able to pass the traffic.
conf t
interface vlan x
no shut
Best Regards,
Bheem
It's been tried but it made no difference.
Does your mpls pseudowire ping without router-altert label and ping mpls ipv4 work from either side.
Also how many hops do we have between these 2 devices.
Can you check show mpls forwarding <loopback of  PE's> on all routers.
Best Regards,
Bheem
Thanks for your help..
It was latter discovered that the problem was with mikrotic router along the path and some link problem could be an issues as well.
But here is a new issues..after I changed the router I have the following:
ping mpls pseudowire 172.27.11.66 333 reply mode router-alert
Sending 5, 100-byte MPLS Echos to 172.27.11.66,
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/4 ms
showing pseudowire is perfect.
But on what situation cause internet connection to be extremely slow even though bandwidth is not restricted?
Everything is fine now but internet browsing through the l2vpn is extremely slow.
Any suggested help will be appreciated.
Problem solve..infrastructural issues can be a pain..on an overlay project like MPLS...
Thanks for your time..
