I have asr 1000 with asr1000rp2-adventerprisek have problem when I gave PPP Multilink to the interface Dialer
radwango1
please Urgent Help
I have ASR 1000 with asr1000rp2-adventerprisek  Version, when I give PPP Multilink to the dialer interface it show following error :
FMFP-3-OBJ_DWNLD_TO_CPP_FAILED: F0: fman_fp_image:
MLP bundle , link download to CPP failed
please urgent help
7 Replies 7
kunapuri
Hello
Kindly provide more information on this, what are steps you have followed to configure the MLPPP on dialer interface. Usually configuration steps in certain order should not impact, just trying to understand if there could be any bug.
Also can you try if you are facing this issue with ipbase image as well.
Kunal
this error comes with the command PPP multilink, it is a lot of letters and numbers and then this last line comes this message
MLP bundle 181, link 178 download to CPP failed
the configuration still not installed but I configured just the following lines
interface Virtual-Template
ip unnumbered Loopback2
ip mtu 1440
ip load-sharing per-packet
ip tcp adjust-mss 1400
no logging event link-status
peer default ip address pool
ipv6 unnumbered Loopback2
ipv6 enable
no ipv6 nd suppress-ra
ppp authentication pap chap callin
ppp multilink
ppp multilink fragment delay 100
ppp multilink mrru local 1546
that were the lines used to configure this Dialer, the image must be asr1000rp2-adventerprisek and not Ipbase but I dont tried to use IPbase.
what do think ?
hey
I am using asr1000rp1-adventerprisek9.03.07.01.S.152-4.S1.bin version on LNS/PE router, have not seen such error. please provide full logs and IOS version you are using.
Kunal
%CPPOSLIB-3-ERROR_NOTIFY: F0: cpp_cp: cpp_cp
encountered an error -Traceback= 1#0558fb4de1aff99b805aa3ac906ee7eb
errmsg:7FD42A7E2000+121D cpp_common_os:7FD42D820000+DC08
cpp_common_os:7FD42D820000+14012
MET-DST: %FMFP-3-OBJ_DWNLD_TO_CPP_FAILED: F0: fman_fp_image:
MLP bundle download to CPP failed
asr1000rp2-adventerprisek9.03.12.01.S.154-2.S1-std.bin is the IOS
what do u think ?
Decode reflects to 03.12.01.S.
Can you try with any other version 15.3(3)S4 and see if you are able to reproduce it.
I will try to find out more on this if any bug exist for this.
kunal
I dont think that such error come from the IOS, please rin another direction
have u another idea
I changed the IOS to stable one, the same Problem,
cpp_common_os:7F1C50515000+119EA cpp_common_os:7F1C50515000+1182B evlib:7F1C4F4EC00
%FMFP-3-OBJ_DWNLD_TO_CPP_FAILED: F0: fman_fp_image:  MLP bundle 178, link 177 download to CPP failed
any Idea ?
