BFD over BGP on cisco 7606
waqas.salam
I am using below hardware and software for BFD over bgp for failure detection.
please confirm that BFD is supported over BGP or not on below hardware. as i have configured bfd with my upstream but BFD neighbor is not getting up.
supervisor:WS-SUP720-3B
Model:CISCO7606
Chassis:
Cisco Systems Cisco 7600 6-slot Chassis System
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVENTERPRISEK9-M), Version 15.1(2)S2
BFD details:
bfd interval 999 min_rx 999 multiplier 5
IPv4 Sessions
NeighAddr LD/RD RH/RS State Int
x.x.x.x  8001/35 Down Init Gi6/1
Session Host: Software
OurAddr: x.x.x.x
Local Diag: 0, Demand mode: 0, Poll bit: 0
MinTxInt: 1000000, MinRxInt: 1000000, Multiplier: 5
Received MinRxInt: 2000000, Received Multiplier: 5
Holddown (hits): 8172(0), Hello (hits): 2000(73614)
Rx Count: 45702, Rx Interval (ms) min/max/avg: 1768/2232/2000 last: 1828 ms ago
Tx Count: 73615, Tx Interval (ms) min/max/avg: 88/2004/1758 last: 508 ms ago
Elapsed time watermarks: 0 0 (last: 0)
Registered protocols: CEF BGP
Last packet: Version: 1 - Diagnostic: 0
State bit: Down - Demand bit: 0
Poll bit: 0 - Final bit: 0
Multiplier: 5 - Length: 24
My Discr.: 35 - Your Discr.: 0
lespejel
Level 3
Level 3
It's supported, sometimes there are sync issues and you need to remove and reapply the BFD configuration.
Have you consulted the configuration guide?
https://www.cisco.com/c/en/us/td/docs/ios/12_0s/feature/guide/fs_bfd.html#wp1106001
CCIE 52804
i have re-applied the BFD configuration but still not getting up.
yes , configuration are same as per your article reference.
please help to resolve the issue
@waqas.salam
please attach a text file with the outputs on both routers for:
show run interface
show interface
show run | s router bgp
show bgp ipv4 unicast neighbor [ip]
show bfd neighbors details
also, are you using any kind of redundancy? like dual sup, or chassis or something else?
regards.
CCIE 52804
