02-29-2016 07:43 AM
could someone plz clarify difference between BGP add-path and BGP multi-path concept ?
02-29-2016 11:16 AM
This is outside my area of knowledge.
I think add-path is sending when sending prefixes to a neighbour. multi-path is used with prefixes you have received, and you want to use multiple equal cost paths (outbound).
03-01-2016 02:15 AM
Somewhere I read this :
Add-paths extension allows BGP speakers to send and receive multiple paths for the same prefix without the new paths implicitly replacing any previous ones."
so may be they both are part of same concept..
