BGP and EIGRP redistribution issue
mohikcho2
i am trying to redistribute BGP routes into EIGRP . On the router the routes are correct and leaned via BGP and given preference
but when i check at Core switch the EIGRP is given preference .
I have tried to give redistributed BGP higher metric but even then EIGRP is the first choice for core switch
Can any help why this is happening and how i can solve the issue so that my core switch .
EIGRP-IPv4:(100) (AS 100): Topology Default-IP-Routing-Table(0) entry for 10.107.7.64/26
State is Passive, Query origin flag is 1, 2 Successor(s), FD is 22802688
  Descriptor Blocks:  10.80.55.3 (Vlan155), from 10.80.55.3, Send flag is 0x0
      Composite metric is (22802688/22802432), Route is Internal
      Vector metric:        Minimum bandwidth is 256 Kbit
        Total delay is 500110 microseconds
        Reliability is 255/255        Load is 1/255
        Minimum MTU is 1476        Hop count is 2
  10.80.55.19 (Vlan255), from 10.80.55.19, Send flag is 0x0
        Total delay is 500110 microseconds        Reliability is 255/255
        Load is 1/255        Minimum MTU is 1476        Hop count is 2
  10.80.55.18 (Vlan255), from 10.80.55.18, Send flag is 0x0
      Composite metric is (529920256/529920000), Route is External
      Vector metric:        Minimum bandwidth is 5 Kbit
        Total delay is 700010 microseconds
        Minimum MTU is 1476        Hop count is 1
      External data:        Originating router is 191.10.101.145
        AS number of route is 522        External protocol is BGP, external metric is 0
        Administrator tag is 755 (0x00001293
router bgp 522
no synchronization
bgp log-neighbor-changes
bgp redistribute-internal
network 10.80.15.0 mask 255.255.255.0
redistribute connected
neighbor 172.24.92.1 remote-as 755
neighbor 172.24.92.1 ebgp-multihop 255
distance 20 0.0.0.0 255.255.255.0
no auto-summary
idcrt2#sh run | s r eigrp
router eigrp 100
redistribute bgp 522 metric 5 70000 255 1 1476 route-map BGP-to-EIGRP
network 10.0.0.0
network 191.10.0.0
no auto-summary
no eigrp log-neighbor-changes
Nagendra Kumar Nainar
Hi Mohit,
Did you mena, you have EIGRP and BGP connection between router and core switch?.  Can you give a gist about the topology?.
BTW, between different protocols, you need to tweak the admin distance to prefer and not the metrics. I assume you are receivign from iBGP (whcih is of admin distance 200) and EIGRP (whcih is admin distance of 170) and so EIGRP is preferred.
-Nagendra
thanks nagendra .
our topology is like this . We are running EIGRP and BGP on one core Router and expecting Core switch to learn that route via EIGRP.
