BGP intra confederation AS error
NayAungLin7876
R1 show nei state is Idel for R5. what could be the issues?
R1
router bgp 65505
bgp log-neighbor-changes
bgp confederation identifier 700
bgp confederation peers 65507
neighbor 10.0.9.1 remote-as 900
neighbor 192.168.2.1 remote-as 65505
neighbor 192.168.2.1 update-source Loopback0
neighbor 192.168.2.1 next-hop-self
neighbor 192.168.5.1 remote-as 65507
neighbor 192.168.5.1 update-source Loopback0
R5
router bgp 65507
bgp confederation peers 65505
neighbor 10.0.11.1 remote-as 1100
neighbor 192.168.1.1 remote-as 65505
neighbor 192.168.1.1 update-source Loopback0
neighbor 192.168.7.1 remote-as 65507
neighbor 192.168.7.1 update-source Loopback0
neighbor 192.168.7.1 next-hop-self
pigallo
hello @NayAungLin7876 ,
without seeing any useful output from command "show bgp <AFI> <SAFI> neighbors x.x.x.x" one thing that came into my mind is that you may probably need to disable connected-check since you're using the loopback address to establish the peering.
Otherwise by looking to the output of command i've post above you may find additional info to what could be the reason of idle session among peers.
hope this may help.
Regards.
R1
router bgp 65505
R5
router bgp 65507
pigallo
hope this may help.
Regards.
R1
router bgp 65505
R5
router bgp 65507
Your answer is really help me. As you said, the problem is neighboring EBGP router by using loopback address. So, I use disable-connected-chek that solve this issues. Thank for your kindly suggestions.
