bgp prefix & path
shhirjee
Community Member
How many bytes of mem are used by a 1*prefix & 1*path for in a PE
Shafik,
The output of "show ip bgp summ" gives you a pretty good idea of how much memory is used by BGP to store prefixes, paths and path attributes.
Here's the output with one prefix:
R2#sh ip bgp summ
BGP router identifier 2.2.2.2, local AS number 2
BGP table version is 2, main routing table version 2
1 network entries using 113 bytes of memory
1 path entries using 52 bytes of memory
2/1 BGP path/bestpath attribute entries using 264 bytes of memory
1 BGP AS-PATH entries using 24 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 453 total bytes of memory
BGP activity 1/0 prefixes, 1/0 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
192.168.12.1 4 1 5 4 2 0 0 00:01:06 1
R2#
This will vary depending on the number of attributes (as-path, communities, extended communities, etc) and the number of paths per prefix.
Hope this helps,
