BGP UNSHUT CLARIFICATION
Raja_D
HI,
I need small clarification on bgp unshut.
I actually need to unshut a bgp peer ipv4 for a vrf Voice_data.
While doing it, i did not get into the address-family ipv4 vrf Voice_Data to unshut the bgp peer 135.45.70.225 initially due to which I got the below result added
BGP table version is 1, main routing table version 1
For address family: IPv4 Unicast
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
135.45.70.225   4        xxxxx      0       0        1    0    0 never    Idle
For address family: VPNv4 Unicast
BGP activity 32667/29154 prefixes, 354322/343258 paths, scan interval 60 secs
3510 received paths for inbound soft reconfiguration
BGP activity 32667/29154 prefixes, 350290/343258 paths, scan interval 60 secs
135.45.70.225   4        xxxxx      0       0        1    0    0 3d18h    Idle (Admin)
And when I realized that the actual peer that i need to unshut is under the address-family ipv4 vrf Voice_Data then i have done unshut properly.
xxx(config)#router bgp 54771
xxx(config-router)#add
xxx(config-router)#address-family ipv4 vrf Voice_Data
xxx(config-router-af)#no neighbor 135.45.70.225 shutdown
xxx(config-router-af)#end
xxx#show ip bgp all summary
This is what i notice now.
BGP router identifier x.x.x.x local AS number 54771
135.45.70.225   4        xxxx 0       0        1    0    0 never    Idle
135.45.70.225   4        xxxxx     155     273   145882    0    0 00:00:05     2016
As per above output i now see ipv4 unicast neighborship got added to the ipv4 vrf Voice_data bgp neighborship in the result.
How do i remove only the ipv4 unicast neighborship for 135.45.70.225 without leading to any impact to ipv4 vrf Voice_data . Ultimately I should just be able to see ipv4 vrf Voice_data bgp neighborship result in the show ip bgp all summary output.
Please advise . I am just worried about the configuration if i configure as below might remove complete neighborship configuration or not.
router bgp 54771
no neighbor 135.45.70.225 remote-as xxxxx
This is what i have currently in running config for bgp.
xxx#show run | sec bgp
router bgp 54771
 bgp router-id 135.45.228.34
 bgp log-neighbor-changes
 neighbor 135.45.70.225 remote-as 21326
  redistribute connected
  neighbor 135.45.70.225  activate
  neighbor 135.45.70.225  soft-reconfiguration inbound
James.
Raja_D
I figured it out on my own..
router bgp xxxx
no neighbor x.x.x.x remote as xx
This will just remove the ipv4 unicast peer bgp neighborship without interrupting the bgp peer neighbor x.x.x.x configuration that is under the address-family ipv4...
James.
Raja_D
router bgp xxxx
James.
Virendra Pratap
router bgp 54771
after configure above command . you will get only vpnv4 unicast neighbor . IF your ip address in under vrf so no need to configure it under ipv4 unicast family.
