Can someone explain about frame header size in Ethernet over MPLS
a.chingan
blau grana
Level 7
Level 7
Hello Arun,
Here is some explanation:
http://cciethebeginning.wordpress.com/tag/eompls/
Also I attached pcap file, you can open it in wireshark and look at entire packets. There are some pings 10.0.0.1 <-> 10.0.0.2 between CEs
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
blau grana
Level 7
Level 7
Hello Arun,
Best Regards
Thanks man...you gave a detailed explanation on this.
Arun Chingan
