Can't find the problem
fourmoum1
this is a topology that i'm working on, i'm trying to implement mpls on gns3 but finally i can't ping the destination router, please help me
my router's configuration :
CE1A, CE1B, CE2A, CE2B, CE3A, CE3B : (same configuration on all custumer routers, only addresses change)
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Serial0/0
ip address 10.1.1.1 255.255.255.252
serial restart-delay 0
clock rate 64000
router rip
version 2
network 1.0.0.0
network 10.0.0.0
no auto-summary
ip http server
no ip http secure-server
PE1, PE2, PE3 (same configuration on all PEs routers, only addresses change)
ip cef
ip vrf cust_a
rd 100:100
route-target export 100:100
route-target import 100:100
ip vrf cust_b
rd 100:200
route-target export 100:200
route-target import 100:200
interface Loopback0
ip address 172.16.1.1 255.255.255.255
interface Serial0/0
ip vrf forwarding cust_b
ip address 10.1.1.2 255.255.255.252
clock rate 64000
interface Serial0/1
ip vrf forwarding cust_a
clock rate 64000
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
interface FastEthernet2/0
ip address 192.168.1.1 255.255.255.252
duplex auto
speed auto
mpls label protocol ldp
mpls ip
mpls mtu 1512
router ospf 1
log-adjacency-changes
network 172.16.1.1 0.0.0.0 area 0
network 192.168.1.0 0.0.0.3 area 0
router rip
address-family ipv4 vrf cust_b
  redistribute bgp 1
  network 10.0.0.0
  no auto-summary
  version 2
exit-address-family
address-family ipv4 vrf cust_a
  redistribute bgp 1
  network 10.0.0.0
  no auto-summary
  version 2
exit-address-family
router bgp 1
no synchronization
bgp log-neighbor-changes
neighbor 172.16.1.2 remote-as 1
neighbor 172.16.1.2 update-source Loopback0
neighbor 172.16.1.3 remote-as 1
neighbor 172.16.1.3 update-source Loopback0
no auto-summary
address-family vpnv4
  neighbor 172.16.1.2 activate
  neighbor 172.16.1.2 send-community extended
  neighbor 172.16.1.3 activate
  neighbor 172.16.1.3 send-community extended
exit-address-family
  redistribute rip
  no synchronization
exit-address-family
  redistribute rip
  no synchronization
exit-address-family
ip http server
control-plane
P router
ip cef
interface FastEthernet0/0
ip address 192.168.1.6 255.255.255.252
duplex auto
speed auto
mpls ip
mpls mtu 1512
interface FastEthernet1/0
ip address 192.168.1.9 255.255.255.252
duplex auto
speed auto
mpls ip
mpls mtu 1512
ip address 192.168.1.2 255.255.255.252
duplex auto
speed auto
mpls ip
mpls mtu 1512
interface FastEthernet3/0
no ip address
shutdown
duplex auto
speed auto
router ospf 1
network 192.168.1.4 0.0.0.3 area 0
network 192.168.1.8 0.0.0.3 area 0
ip http server
control-plane
regards !
2 Accepted Solutions
Mohammed Imran Khan
Hello Mohamed,
Can you please confirm what you are unable to ping? CE-CE? Is PE-PE pingable (both vrf and LSP)?
If CE-CE is not pinging (but LSP is up and PE-PE vrf routes are pinging) then try this on PE:
router rip
  redistribute bgp 1 >>>>
  network 10.0.0.0
  no auto-summary
  version 2
exit-address-family
Imran
I agree with Imran (+5): Setting a seed-metric for the bgp-to-rip redistribution should fix the problem.
Alternatively you can use the metric transparent option:
PE_2(config-router-af)#redistribute bgp 1
RIP: received v2 update from 10.1.1.1 on Serial0/0
     10.255.2.0/24 via 0.0.0.0 in 16 hops  (inaccessible)
PE_2(config-router-af)#redistribute bgp 1 metric transparent
RIP: sending v2 update to 224.0.0.9 via Loopback1 (10.255.1.1)
RIP: build update entries
        10.255.2.0/24 via 0.0.0.0, metric 1, tag 0
Defining a seed-metric is important when the IGP is RIP or EIGRP.
Rolf
Mohammed Imran Khan
Hello Mohamed,
router rip
  network 10.0.0.0
  no auto-summary
  version 2
exit-address-family
Imran
Rolf
fourmoum1
Thank you Imran and Rolf, it works for me now.
Mohamed
Mohammed Imran Khan
Thanks Rolf! :-)
Mohamed, I am glad issue is resolved now.
Imran
