Hi Gang,
I'm trying to transpose this simple MPLS tutorial to a Nexus 9000 core using VIRL on Packet.
There's a few different ways things are done on the Nexus but by and large it was going well until I got to the point where customer routes need to be redistributed across the MPLS core to "join" the customer sites. The section I am specifically referring to follows this image about three quarters into the tutorail:
At this point, the tutorial suggests adding this to R1's config:
router bgp 1
address-family ipv4 vrf RED
redistribute ospf 2
...but having reviewed this document it appears there is no way to redistribute the ospf routes into MBGP and vice-versa *without* a route map. Consulting context help on the cli seems to confrim:
R1# conf term
Enter configuration commands, one per line. End with CNTL/Z.
R1(config)# router bgp 1
R1(config-router)# vrf RED
R1(config-router-vrf)# address-family ipv4 unicast
R1(config-router-vrf-af)# redistribute ospf 2 ?
route-map Route-map applied to redistributed routes
R1# conf term
R1(config)# router ospf 2
R1(config-router)# redistribute bgp 1 ?
route-map Policy to constrain redistribution
R1(config-router)#
Neither of the two examples admit "CR" as an option - you must follow the command with 'route-map' for it to be valid.
Can someone confirm if that's the case?
Martin
