MPLS
Hi dear community,I am facing an issue with the following setup :Ping is not OK for the BGP EVPN VPWS Service (Vlan / EVC 20).Here is the configuration of the involed PE :Cisco PE ISR1111:interface GigabitEthernet0/0/1 no ip address negotiation auto ...
Jerems by • Spotlight
  • 10534 Views
  • 50 replies
  • 1 Helpful votes
How can I get started with MPLS? I like reading books but sometime books are very boring like the concepts must be known but I believe in practicals instead of just theory. Theory seems more interesting to me after Practicals. I haven't found any boo...
Hi All,I am running a lab using Cisco xrd 7.11.2 control-plane on ContainerLab.In the lab topology I have an ASBR using InterAS-Option-C to exchange IPv6 prefixes with another AS. That ASBR is also a PE router for a VPNv4 and VPNv6 services.VPNv4 wor...
as we know, in one-arm hub-and-spoke L3VPN, we need the hub CE to advertise a default route so spokes can learn it to enable spoke-to-spoke traffic.however, if the hub PE also provides internet access by advertising another default route, there will ...
daniel ng by • Spotlight
  • 757 Views
  • 6 replies
In lab testing with MPLS-TE and SR-TE I see that with MPLS-TE policy and tunnel active, when SR-TE policy is configured, the route announced by SR-TE takes preference over MPLS-TE.Following is the output from MPLS-TE:RP/0/RP0/CPU0:pe2#sh route 10.0.0...
We have an MPLS L3VPN connectivity issue affecting one specific remote site. Topologi is below.AGDM has MP-BGP VPNv4 sessions with both XINDI ASR920 and 4YOL ASR920. The VRF is VOIP. AGDM has ibgp with MSE2 (AS34170).AGDM successfully learns the VOIP...
Hello, everyone.I'm studying MPLS for my CCNP exam. I understand that FEC is a group of packets that will be forwarded along the same path and will be treated the same way in terms of priority and treatment.I also understand that all packets that bel...
Mitrixsen by • Spotlight
  • 341 Views
  • 0 replies
Hello,As my pre-final exam topic for CCNP SP, I’m currently studying MPLS and would like to ask a quick question. Is MPLS considered a tunneling protocol?I’ve always understood tunnels to have two key characteristics: encapsulation (for example, with...
  • 1076 Views
  • 6 replies
Hello all, am trying to test MPLS VPNv4 feature on EVENG and my goal is to import default Internet route and MPLS VPNv4 with two different VRFS as mentioned below, Can someone guide me furhter to fix this issue. PE225-PE01#show running-config | sec v...
uni1389 by • Level 3
  • 719 Views
  • 3 replies
Hi everyone, I am trying to configure ECMP for Segment Routing Traffic Engineering on an ASR920. Here is the configuration I have applied: segment-routing traffic-engsegment-list name SL_TEST_PATH_1index 10 mpls label 17201index 20 mpls label 15984 s...
config by • Level 3
  • 1740 Views
  • 8 replies
I have Both NCS540 router and getting GTP loss on site, now i want to configure ECMP for load balancing, one media is MW and Secondary media is UBR so pls suggest how can i configure ECMP and how can i sure ECMP are working fine in router ?
soheljujara by • Frequent Visitor
  • 400 Views
  • 0 replies
in IOS XE (and also XR if you want to), you need to use hex value to define affinity (admin group) for link colouring in RSVP-TE.since you can only configure one affinity per interface and one affinity/mask pair per LSP, does that mean the mask match...
  • 1250 Views
  • 5 replies
Unanswered Topics
Top Solution Authors
