02-28-2006 08:42 AM
I am new to MPLS and we are in the process of converting to MPLS from a Frame-Relay WAN. I was tryingto find some info for router requirements for the Customer Edge and IOS requirements. Any info would be appreciated.
02-28-2006 08:56 AM
there are no mpls specific requirements required by ce routers. You have only to consider the rotuing protocol support of the the pe router. In MPLS VPN not all routing protocols are vrf-aware. At least static routing, RIPv2, OSPF and EBGP are supported.
For latest information, please check the Cisco web pages.
Frank
03-20-2006 11:49 PM
Any Cisco routers with IOS 12.3 and above would be alright.
jasrine47
