04-10-2017 02:06 AM
Hi.
Please help me.
Is there an analog of the syntax of the command on ASR9001 :
mpls ldp tcp pak-priority
ip local policy route-map
At Cisco ME3800s they are.
04-12-2017 02:03 AM
Regarding the “mpls ldp tcp pak-priority” cmd:
In IOS XR when LDP sends hello discovery or protocol control messages, these are marked using the default control packet precedence value (6, or dscp 48).
You can use the “(config-ldp)# signalling dscp” command to override the default DSCP 6 value to something else.
Regarding the “ip local policy route-map” cmd:
IOS XR is using ABF (ACL Based Forwarding), but to my knowledge there’s no equivalent for this cmd in XR, but what are you trying to accomplish please? Can’t it be done with static routes?
adam
netconsultings.com
::carrier-class solutions for the telecommunications industry::
05-17-2017 05:11 AM
Hi Adam. Thank you for trying to help. Bat mpls ldp tcp pak-priority No such command.
