cisco & juniper l2circuit interoperability issue
diegosaav
Hi folks,
After reading some docs about configuration options between them I have not connectivity yet.
My topology is as follow:
CEside <> JuniperM20 <> JuniperM20 <> Cisco7606 <> CEside
The configs:
neighbor y.y.y.y {
    interface ge-2/0/0.1950 {
        virtual-circuit-id 1950;
        no-control-word;
        mtu 1500;
        ignore-encapsulation-mismatch;
        ignore-mtu-mismatch;
show configuration interfaces ge-2/0/0.1950
encapsulation vlan-ccc;
vlan-id 1950;
family ccc;
sh run int g1/14.1950
interface GigabitEthernet1/14.1950
description PW-TEST-ING
encapsulation dot1Q 1950
xconnect x.x.x.x 1950 encapsulation mpls
end
Some troubleshooting commands:
Cisco side:
sh mpls l2transport vc detail
Local interface: Gi1/14.1950 up, line protocol up, Eth VLAN 1950 up
  Destination address: x.x.x.x, VC ID: 1950, VC status: down
    Output interface: none, imposed label stack {}
    Preferred path: not configured
    Default path: no route
    No adjacency
  Create time: 1d18h, last status change time: 1d18h
  Signaling protocol: LDP, peer x.x.x.x: up
    Targeted Hello: y.y.y.y(LDP Id) -> x.x.x.x
    MPLS VC labels: local 1697, remote unassigned
    Group ID: local 0, remote unknown
    MTU: local 1500, remote unknown
    Remote interface description:
  Sequencing: receive disabled, send disabled
  VC statistics:
    packet totals: receive 0, send 0
    byte totals:   receive 0, send 0
    packet drops:  receive 0, send 0
Juniper side:
show l2circuit connections neighbor y.y.y.y | find ^Neighbor
Neighbor: y.y.y.y
    Interface                 Type  St     Time last up          # Up trans
    ge-2/0/0.1950(vc 1950)    rmt   VC-Dn  -----                          0
      Remote PE: y.y.y.y, Negotiated control-word: No Encapsulation: ETHERNET
      Incoming label: 589520, Outgoing label: 1697
      Local interface: ge-2/0/0.1950, Status: Up, Encapsulation: VLAN
Juniper logs:
Jul 26 15:09:16.063733 [add] l2circuit VC l2ckt_vc_adv_recv (cw-bit 0, encaps ETHERNET, vc-id 1950,label 1697, mtu 1500, cb-size 0, no vlan-id, TDM payload size 0 bytes,  TDM bitrate 0 (xDS0)) received from PE y.y.y.y
Jul 26 15:09:16.063823 [l2ckt_vc_adv_recv] Intf ge-2/0/0.1950 (VC-ID 1950) updated from signalled info: label 1697, encaps ETHERNET, cw-bit 0, mtu 1500, cb-size 0,  TDM payload size 0 (bytes), TDM bitrate 0 (xDS0) no vlan-id
Jul 26 15:09:16.065538        Triggering VC status update timer for intf ge-2/0/0.1950
Jul 26 15:09:16.114307 [vc_intf_vc_status_update] Recomputing the status of the VC for interface : ge-2/0/0.1950
Jul 26 15:09:16.114335 vc_intf_vc_status_update] interface : ge-2/0/0.1950 vc status = intf Up : intf_up = TRUE
Jul 26 15:09:16.114360 [vc_intf_vc_status_update] interface : ge-2/0/0.1950 UP adv_down = 0 : vc_down = 0, ccc_up = 1
Jul 26 15:09:16.114383 vc_intf_vc_status_update] interface : ge-2/0/0.1950 VC PRESENT
Jul 26 15:09:16.114453 [vc_intf_vc_status_update] interface : ge-2/0/0.1950 Done Computing adv, vc down and ccc_up status adv_down = 1, vc_down = 1, ccc_up = 0
Any ideas would be appreciated.
Thx!
-d
9 Replies 9
Harold Ritter
Hi Diego,
Do you have an functionning LSP from the Cisco to the Juniper? Can you do a "show ip cef x.x.x.x int" from the Cisco side.
Hi Harold,
There is the output of "show ip cef x.x.x.x int" command from the Cisco rtr.
#sh ip cef x.x.x.x internal
x.x.x.x/32, epoch 9, RIB[S], refcount 6, per-destination sharing
  sources: RIB
  feature space:
   LFD: x.x.x.x/32 1 local label
   local label info: global/1699
        contains path extension list
        disposition chain 0x547E5088
        label switch chain 0x547E5088
   IPRM: 0x00058000
   Broker: linked
  ifnums:
   GigabitEthernet2/15(35): y.y.y.y <<<< /30 link between c7606 <> jm20
   path_list contains at least one resolved destination(s). HW not notified
  path 53503608, path list 4571D938, share 1/1, type recursive, for IPv4
  recursive via y.y.y.y[IPv4:Default], fib 45615D2C, 1 terminal fib
    path 53504244, path list 4571DD58, share 1/1, type adjacency prefix, for IPv4
      MPLS long path extensions: MOI flags = 0x0 label 300512
    attached to GigabitEthernet2/15 label 300512, adjacency IP adj out of GigabitEthernet2/15, addr y.y.y.y
53747800
  long extension for path if GigabitEthernet2/15 next hop y.y.y.y:
  output chain: label 300512 TAG adj out of GigabitEthernet2/15, addr y.y.y.y 53745E80
and...
#show mpls forwarding-table x.x.x.x
Local  Outgoing      Prefix            Bytes Label   Outgoing   Next Hop
Label  Label or VC   or Tunnel Id      Switched      interface
1699   300512        x.x.x.x/32   51172         Gi2/15     y.y.y.y
Many thx for your time!
-d
Hi Diego,
What IOS version do you run on the 7606?
Hi Harold,
Sorry for the delay, the IOS version that we're running on the C7606 is:
#sh ver | i IOS
Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRB7, RELEASE SOFTWARE (fc1)
Thx,
-d
Hi Diego,
This is a pretty old version of IOS. I would recommend you upgrade to something more recent before proceeding with more troubleshooting.
Hi Harold,
Which version of IOS do you recommend to upgrade based on the following features of the box?
cisco CISCO7606-S (R7000) processor (revision 1.1) with 983040K/65536K bytes of memory.
Processor board ID FOX1340GJxx
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
35 Virtual Ethernet interfaces
146 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Thx,
-d
Hi Diego,
I would recommend the latest version (15.3(1)S2). You currently do not have enough flash memory and will therefore need to upgarde.
Thx Harold, we'll be upgrading to the latest version and keep you posted.
-d
Jerems
Old thread but new potential answer
On juniper side "encapsulation-type ethernet" instead of "encapsulation-type ethernet-vlan" should help
