Cisco Router 12406 MPLS physical interface problem!
vjfl0rin1
I want to monitor a router interface with a NMS program, but i can't collect the data from this interface.
I was trying with:
snmpwalk  -v2c -c community 10.100.xxx.xx 1.3.6.1.2.1.2.2.1.19 the result was that is missing the oid named ifOutDiscards for the interface that i want to monitor.
How can i fix this problem?
Giuseppe Larosa
Hello Flo,
what kind of interface is this ? is it a POS Sonet/SDH interface?
my guess is that ifOutDiscards may be related to LAN type interfaces
"The number of outbound packets which were chosen to be
discarded even though no errors had been detected to prevent
their being transmitted.  One possible reason for discarding
such a packet could be to free up buffer space.
Discontinuities in the value of this counter can occur at
re-initialization of the management system, and at other
times as indicated by the value of
ifCounterDiscontinuityTime."
Actually from description it looks like the variable should apply also to POS interfaces
see
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=1.3.6.1.2.1.2.2.1.19&translate=Translate&submitValue=SUBMIT
you can also check the supporting images from the link above
Hope to help
Giuseppe
Cisco XR 12000 Series Router
MPLS interface, SDH.
Check again the configuration since a few defaults can be different in IOS XR.If you post it we can helps little bit more
Alessio
