control-word usage in l2vpn question?
fly
Level 2
Level 2
Hi,Dear Sir/Madam,
    we config a l2 vpn between two 6509,  it worked, but we move line between two 6509 to SDH to extend the distance.
   but the sdh device can't allowed <64 bytes packet, we found when <64 bytes packet send from 6509 was dropped by sdh device.
   can we config control-word on two 6509 to auto pad packet to 64 bytes?
   but we found one 6509 don't have control-word ,the other 6509 has control-word configured, but two 6509 can't negotiate control-word?
   can i auto padding to 64 bytes by using control-word?
pseudowire-class eompls
 encapsulation mpls
 interworking ethernet
interface GigabitEthernet2/2/1
 description
 no switchport
 no ip address
 no keepalive
 xconnect x.x.x.x 1000 pw-class eompls
router 1#sh mpls l2transport vc 1000 detail
Local interface: Gi2/2/3 up, line protocol up, Ethernet up
  Destination address: x.x.x.x, VC ID: 1000, VC status: up
    Output interface: Gix.x.x.x, imposed label stack {100}
    Preferred path: not configured
    Default path: active
    Next hop: x.x.x.x
  Load Balance: none
  Flow Label: Disabled
  Create time: 2d05h, last status change time: 2d05h
  Signaling protocol: LDP, peer x.x.x.x:0 up
    Targeted Hello: x.x.x.x(LDP Id) -> x.x.x.x
    Status TLV support (local/remote)   : enabled/not supported
      Label/status state machine        : established, LruRru
      Last local dataplane   status rcvd: no fault
      Last local SSS circuit status rcvd: no fault
      Last local SSS circuit status sent: no fault
      Last local  LDP TLV    status sent: no fault
      Last remote LDP TLV    status rcvd: not sent
    MPLS VC labels: local 147, remote 100
    Group ID: local 0, remote 0
    MTU: local 1500, remote 1500
    Remote interface description:
  Sequencing: receive disabled, send disabled
  VC statistics:
    packet totals: receive 23300, send 23299
    byte totals:   receive 2893290, send 2602655
packet drops:  receive 0, seq error 0, send 0
6509-2
 encapsulation mpls
control-word
interface FastEthernetx/x
 no ip address
6509-2#sh mpls l2transport vc detail
Local interface: Fax/x up, line protocol up, Ethernet up
    Output interface: x/x, imposed label stack {147}
    Next hop: x.x.x.x
  Load Balance: none
  Signaling protocol: LDP, peer x.x.x.x8:0 up
    Targeted Hello: x..x.x.x(LDP Id) -> 10.1.1.x, LDP is UP
      LDP route watch                   : enabled
      Last local dataplane   status rcvd: No fault
      Last local SSS circuit status rcvd: No fault
      Last local SSS circuit status sent: No fault
      Last local  LDP TLV    status sent: No fault
      Last remote LDP TLV    status rcvd: Not sent
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local 100, remote 147
    Remote interface description: PE-PuDong-Test
  Control Word: Off (configured: enabled) <<<<<<---control-word configured but not work
  VC statistics:
    transit packet totals: receive 23279, send 23279
    transit byte totals:   receive 2600434, send 2564554
    transit packet drops:  receive 0, send 0
Nagendra Kumar Nainar
Hi Fly,
Enabling control-word will only add additional 4 bytes. It will not pad a packet uptil any minimum size. So I doubt enabling CW is going to help.
Regarding the CW staying as OFF, I think it depends on the line card support. SOme cards are not capable of supporting control-word for edge/core functionality.
What is your CE facing linecard?. Can you check "show mpls l2transport hw-capability interface fax/x" (This is the interface under which you enabled xconnect") and see if control-word processing is supported or not?.
-Nagendra
if enable control-word can't auto pad packet to 64 bytes, that doesn't help us.
we capture packet on sdh devices , found sdh drop packet < 64 bytes.
Is there any method to support pad small packet?
Hi,Nagendra,
   I think customer mislead me.
    for ethernet interface, if frame <64 bytes, ethernet interface driver will pad the frame and send out.
So this padding don't happen at l2vpn encapsulation , and happend at ethernet interface.
   If etherner interface on SDH device receive <64 bytes frame , it means there may be some  duplex,mtu, cable problem , not l2 vpn encapsulation problem
   I will check 651----sdh----652 ethernet config! \
   thank you!
Tom
