Bookmark
Subscribe
7131
COS to EXP bits mapping
amitbatra
Hi Guys,
theoretically and practicaly the DSCP or IP prec values are copied to EXP bits of shim header.
Does that same applies to when Atom is configured ?? because in Atom the PE receives traffic from CE and that could be vlan tagged. PE imposes the MPLS tag received from egree PE and then imposes the tunnel tag and send it to the egress PE.
are the COS values copied to the appropriate EXP bits at this time ??
16 Replies 16
Hi Niranjan,
We are trying to schedule the SPAN with customer to find out where have set the voice to CS5 instead of EF.
Our PE policy is not changing the customer DSCP setting so we can't remap their traffic.
Will let you know what we see from the Sniffer.
Ok. Sure.
Thanks.
