CPE Management VRF (one more)
sultan-shaikh
Level 3
Level 3
Hi Friends,
Sorry for starting one more thread on the same. I know that this topic has already been beaten to death here.
So here is the problem:
I have 2 back to back connected 7600s, let's say PE-1 and PE-2.
I have configured a Management VRF on PE-1 and pulled in Loopback 0 and another interface connected to my Management (10.253.2.0 network).
I have configured a test VPN (VRF-101) between PE-1 and PE-2 and have connected 2 CPE devices (2800s). PE-1 to CPE-1 and PE-2 to CPE-2 is eBGP.
My VPN is working fine with both CPE loopback and LAN routes advertised across.
I want to manage these CPEs, here is the configuration I created, (after going through this forum!), unfortunately for me it is not working.
PE-1 Configuration:-
ip vrf Management-VRF
rd 65000:500
export map MgmtLAN
route-target export 65000:500
route-target export 65000:161
route-target import 65000:500
route-target import 65000:162
ip vrf VRF-101
rd 65000:101
export map MgmtLoopbacks
route-target export 65000:101
route-target import 65000:101
route-target import 65000:161
interface Loopback0
description System Control Interface
ip address 10.253.254.1 255.255.255.255
interface Loopback1
description MGMT Control Interface
ip vrf forwarding Management-VRF
ip address 10.253.250.1 255.255.255.255
interface GigabitEthernet5/2
description To NMS_MGMT_CE01
ip address 10.253.255.5 255.255.255.252
address-family ipv4 vrf Management-VRF
no synchronization
bgp router-id 10.253.250.1
redistribute connected
redistribute static
neighbor 10.253.255.6 remote-as 65000
neighbor 10.253.255.6 activate
neighbor 10.253.255.6 send-community both
exit-address-family
address-family ipv4 vrf VRF-101
no synchronization
redistribute static
exit-address-family
access-list 1 permit 10.253.254.0 0.0.0.255 log
access-list 2 permit 10.253.224.2
access-list 2 permit 10.253.224.1
route-map MgmtLAN permit 10
match ip address 1
set extcommunity rt 65000:161
route-map MgmtLoopbacks permit 10
match ip address 2
set extcommunity rt 65000:162 additive
PE-2 Configuration:-
ip vrf VRF-101
rd 65000:101
interface Loopback0
ip address 10.253.254.65 255.255.255.255
interface GigabitEthernet2/1/1.101
encapsulation dot1Q 101
ip vrf forwarding VRF-101
ip address 10.1.0.2 255.255.255.252
no synchronization
redistribute static
neighbor 10.1.0.1 remote-as xxx
neighbor 10.1.0.1 activate
neighbor 10.1.0.1 next-hop-self
exit-address-family
Requesting some help in understanding this.
Cheers
~sultan
2 Accepted Solutions
ok so the loopback from CPE 1 is in the management table. Use the same logic on PE2 to bring in the loopback of CPE 2. I presume from your initial post that even tho you have CPE 1's loopback in the table that you cannot ping it? If this is the case then have a little think about what is your source address of your ping :)
you leak the ip addresses of your servers out of your vrf so for instance route-map then add an ext-comm of say 999 or 666 :) Then all you do is import that wherever you want to manage.
9 Replies 9
romccallum
Level 4
Level 4
on PE1 there is no bgp to the CPE. On PE2 there IS bgp to the CPE but no route map changing the ext comm
Hi Robert,
Thanks for your response, between PE-1 and CPE-1 there is static routing hence no BGP. I have added appropriate routes, am getting loopback and LAN routes of CPE across the VPN.
Requesting you to please let me know what route-map am I supposed to give.
Also, I am getting CPE-1 loopback in Managment VRF but not for CPE-2.
Please reply...
Cheers
~sultan
Hi Robert,
That was quick !!!
Yes, I have the CPE-1 in Management table, and I can also ping the same, the source being PE-1's loopback interface, which I had 'pulled' in Management VRF.
CPE-2 is not in the Management table, so as I understand you are suggesting that I configure acls and route-maps in PE-2 (as I have done on PE-1), in that case even if the route comes in it will have 'next-hop' as, I presume, PE-2 loopback, and my source would be PE-1 loopback?? !!
I am sorry if I am sounding confused...
Cheers,
~sultan
bang on mate. Once the route is in you shall only be able to ping from PE1's loopback address as this shall be propogated into the CPE's.
So how do I get my Management servers to ping to CPE devices?
I will be working on this again today and update the forum...
Cheers,
~sultan
Hi Robert,
Thanks a ton for your insightful comments they really helped a lot.
Further this book was also of great help MPLS VPN Security, specifically Chapter 8, really articulates the basis for this kind of configuration.
Cheers
~sultan
np sultan best of luck.
