Cross-site Layer2 VPN
francisco_1
Level 7
Level 7
In the diagram i have 2 sites. In site 1 i have 2 PE devices with Vlan 3,33 in VTP database and couple of servers in both vlans. Need to extend both vlans broadcast domain to site 2 access layer switches. MPLS/LDP enable on PE's. I am assuming that without another access layer attached to PE3/PE4 with a tunk interface i cannot enable psedowire on PE3/PE3! since i need an (L3 - without an ip address) interface to enable xconnect on. Will vlan-base psedowire work? but will need a SIP card on the PE's since they are 6509!!
Any comment? Let me know you need more clarification..
Francisco.
Laurent Aubert
Hi Francisco,
You're right. You need a SIP card for your uplinks if you want to apply the xconnect to an SVI interface.
You could try creating a trunk for VLAN 3 and 33 between PE3 and PE4. Assuming all the servers are connected to PE3 (there are 2x PE3 on your drawing ;-) ), you could apply the xconnect on PE4 trunk interface only to PE1 as primary and PE2 as secondary:
xconnect 192.168.124.1 10 encapsulation mpls
backup peer 192.168.124.2 20
Laurent.
