DSCP to MPLS EXp bit mapping how ???
hjerbandi
If Ip precedence is used, then mapping the same to exp bit is one-2-one. If DSCP is used, then how is the mapping done to exp bit which hs only 8 possible values and where as dscp can hv 64 possible vaues..
any ur/doc explaning thi mapping would be apperciated.
thx
hanu
Harold Ritter
No matter if you you DSCP or IP precedence, only the first 3 bits of the IP header TOS field are used since the exp bits field is 3 bit long.
The mapping from DSCP to MPLS exp bits is:
0-7 to 0
8-15 to 1
16-23 to 2
24-31 to 3
32-39 to 4
40-47 to 5
48-55 to 6
56-63 to 7
Hope this helps,
hi
thx for the explanation, i see the same mapping done in Ip solution centre also. Got confused with one of the rfc explaining about mpls and Diff serv :)
thx
hanu
regarding this control plane packets ( cs6 and cs7 ) are they mapped to exp bits ?  are this contol plane pakrets labeled ?
