EoMPLS and L2TPv3
rickwhittington
Good morning everyone.... I was wondering if someone could help me out with this?
I have setup a dev lab setup to test some stuff out before I go forward and move to production but I have hit a brick wall...
Here is a general setup Diagram.
                         HQ_SW-CE
                         HQ_RTR-PE
               branch2_rtr     branch3_rtr
               BR2_SW-CE     BR3_SW-CE
Here is the hardware
HQ-2811 with HWIC-4ESW ios adventerprisek9-mz.151-3.T1.bin
Branch2-2811 ios adventerprisek9-mz.151-3.T1.bin
Branch3-1841 ios advipservicesk9-mz.151-4.M.bin
Switches are 3560G but in production will probably be 2960s and 2950s
I started out with L2TPv3 which worked and did not work. If I went to the HQ_SW and show cdp and STP for VLAN 42 which is a MGMT vlan.
HQ_SW>show cdp ne
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
HQ_RTR           Gig 0/2           178             R S I  2811      Fas 0/2/2
HQ_RTR           Gig 0/1           157             R S I  2811      Fas 0/2/1
BRANCH3_SW       Gig 0/2           129             R S I  WS-C3560G Gig 0/14
BRANCH2_SW       Gig 0/1           130             R S I  WS-C3560G Gig 0/11
HQ_SW>show spanning-tree vlan 42
VLAN0042
  Spanning tree enabled protocol ieee
  Root ID    Priority    32810
             Address     001e.79d1.c880
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32810  (priority 32768 sys-id-ext 42)
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi0/1               Desg FWD 19        128.1    P2p
Gi0/2               Desg FWD 19        128.2    P2p
Now if if I try and ping 172.42.1.2 (BRANCH 2 INT VLAN 42) I get no where...
HQ_SW>ping 172.42.1.2
Sending 5, 100-byte ICMP Echos to 172.42.1.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
HQ_SW>ping 172.42.1.3
Sending 5, 100-byte ICMP Echos to 172.42.1.3, timeout is 2 seconds:
Also I Have a mac address table but the l2 MACs for the remote switches do not show up, arps for those ip addresses show up as incomplete as well.
I switched to EoMPLS and had the same issue.
What we are trying to do is setup a backup link for a server should a main link fail. the HQ Router should be able to terminate MANY L2 tunnels. Basically I see that the HQ_PE router almost like a switch and interface 1 will go to NY, int 2 will go to Chicago, int 3 will go to Dallas, etc. Since this is a backup connection we are trying to deploy it as cheaply as possible. We did this with a 4esw/9esw on the HQ router because it will support up to 15 or so sites that we want to do. The issue is that even when the xconnect line is added to the hwic it does not want to pass traffic. EoMPLS is the same thing.... Can anyone help me out? Also does anyone know if I went to a older ME-sw for the HQ if it would support the MPLS commands from the HQ router?
Also the l2tun and mpls all show up see below
BRANCH2#show l2tun
L2TP Tunnel and Session Information Total tunnels 1 sessions 1
LocTunID   RemTunID   Remote Name   State  Remote Address  Sessn L2TP Class/
                                                           Count VPDN Group
1543017164 4034467245 HQ_RTR        est    10.0.0.1        1     l2tp_default_cl
LocID      RemID      TunID      Username, Intf/      State  Last Chg Uniq ID
                                 Vcid, Circuit
908667366  3759587721 1543017164 104, Fa0/1           est    00:58:18 4
8 Replies 8
Hi Rick,
I can see you are trying to run IPsec over the pseudowire.
AFAIK ,If you are trying to run IPsec over EoMPLS it wont work as the resulting packet would be a labeled packet and there is no ip involved. Hence IPsec will not work as for IPsec to work you would need  IP Transport.
However, in your L2TPv3 which is IP based, it will work because the resulting packet is a IP packet. Is your IPsec vpn working fine? Did you run any debugs to collect some more information? do you see packets been encrypted and decrypted when you execute the command "sh ipsec sa peer "
Edit: Can you ping the loopbacks between the 10.0.0.1, 10.0.0.2, 10.0.0.3 between the routers first?
Kishore
Message was edited by: Kishore Chennupati
In response to can I ping the loopbacks yes, I can ping all loopbacks.
In response to the IPsec I think I may need to clarify...... I am first running IPsec between routers. Then on loop0 I am terminating GRE tunnels. The IPsec tunnels are used to run gre throught he loopbacks hence the access list for interesting traffic. Once the GRE tunnels are established I am then running the pseudo-wire through the GRE to setup either L2TPv3 or EoMPLS. The mpls neighbors are done via the Loop1 IP addresses. Everything comes up as intended, however it seems traffic just does not pass through the pseudo-wire.
To confirm, L2TPv3 does not work, EoMPLS does not work, both do not work as intended. I can only see the CDP neighbor information but traffic does not pass.
When you send the pings do you see the encrypted/decreypted packets increment when you exexute the "sh ipsec sa peer 192.168.1.2". IPsec is your base here if that doesnt work well then nothing will work well. The control plane might be fine i.e exchaning polices etc and all as your config looks fine. But, if the forwarding is not working then there might be something wrong with ground work. I will take the following steps to fix this
1 Troubleshoot IPsec. check if IPsec is all good
2. Check GRE
3. Check L2tpv3
I will try and LAB this once I can get some time.
Kishore
I am positive the ipsec tunnel is good to go as I have set them up before tons of times, same with the GRE. Here is the requested information however.
HQ_RTR#show crypto ipsec sa peer 192.168.2.2. The reason you will see two is because of the ACLs i have
Extended IP access list 102
    10 permit ip host 10.0.0.1 host 10.0.0.2 (19462 matches)
    20 permit ip host 10.0.0.2 host 10.0.0.1
Extended IP access list 103
    10 permit ip host 10.0.0.1 host 10.0.0.3 (17404 matches)
    20 permit ip host 10.0.0.3 host 10.0.0.1
HQ_RTR#
You should look at only the ACLs witht he matchs so no the first SA but the second for the same peer see below
interface: FastEthernet0/0
    Crypto map tag: VPN, local addr 192.168.1.2
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (10.0.0.2/255.255.255.255/0/0)
   remote ident (addr/mask/prot/port): (10.0.0.1/255.255.255.255/0/0)
   current_peer 192.168.2.2 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: 192.168.1.2, remote crypto endpt.: 192.168.2.2
     path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet0/0
     current outbound spi: 0x0(0)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
   local  ident (addr/mask/prot/port): (10.0.0.1/255.255.255.255/0/0)
   remote ident (addr/mask/prot/port): (10.0.0.2/255.255.255.255/0/0)
    #pkts encaps: 4548, #pkts encrypt: 4548, #pkts digest: 4548
    #pkts decaps: 5004, #pkts decrypt: 5004, #pkts verify: 5004
    #send errors 2, #recv errors 0
     current outbound spi: 0xD5EFC998(3589261720)
     PFS (Y/N): Y, DH group: group2
     inbound esp sas:
      spi: 0x692F80B1(1764720817)
        transform: esp-aes esp-sha-hmac ,
        in use settings ={Tunnel, }
        conn id: 2003, flow_id: NETGX:3, sibling_flags 80000046, crypto map: VPN
        sa timing: remaining key lifetime (k/sec): (4390208/1595)
        IV size: 16 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 2004, flow_id: NETGX:4, sibling_flags 80000046, crypto map: VPN
        sa timing: remaining key lifetime (k/sec): (4390276/1595)
        IV size: 16 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
HQ_RTR#ping 10.0.0.2 source lo0
Sending 5, 100-byte ICMP Echos to 10.0.0.2, timeout is 2 seconds:
Packet sent with a source address of 10.0.0.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/4 ms
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
    #pkts encaps: 4583, #pkts encrypt: 4583, #pkts digest: 4583
    #pkts decaps: 5042, #pkts decrypt: 5042, #pkts verify: 5042
     inbound esp sas:
        sa timing: remaining key lifetime (k/sec): (4390204/1582)
        IV size: 16 bytes
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        sa timing: remaining key lifetime (k/sec): (4390272/1582)
        IV size: 16 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
HQ_RTR#
HQ_RTR#
Also right now with the L2TPv3 setup I am not using the GRE I had it setup for when I was using EoMPLS. I know the two work as I can see the multicast of the cdp but nothing beyond that..
Rick,
I have labbed your config and it seems to be working as expected. I just labbed L2TPv3o IPsec.  I took the configs from your attachments. Please see the configs and also the result.
HQ Router
LPE1#sh run
Building configuration...
Current configuration : 1571 bytes
upgrade fpd auto
version 12.4
hostname LPE1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
  hidekeys
crypto isakmp policy 100
encr aes
authentication pre-share
group 2
lifetime 28800
crypto isakmp key branch2 address 192.168.2.2
crypto ipsec transform-set VPN esp-aes esp-sha-hmac
crypto map VPN 102 ipsec-isakmp
set peer 192.168.2.2
set transform-set VPN
set pfs group2
match address 102
pseudowire-class L2
encapsulation l2tpv3
sequencing both
ip local interface Loopback0
interface Loopback0
ip address 10.0.0.1 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface GigabitEthernet1/0
no ip address
negotiation auto
xconnect 10.0.0.2 104 pw-class L2
interface GigabitEthernet2/0
ip address 192.168.2.1 255.255.255.0
negotiation auto
crypto map VPN
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.2.2
no ip http server
no ip http secure-server
logging alarm informational
access-list 102 permit ip host 10.0.0.1 host 10.0.0.2
access-list 102 permit ip host 10.0.0.2 host 10.0.0.1
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
LPE1#
BR Router
LPE2#sh run
Current configuration : 1569 bytes
upgrade fpd auto
version 12.4
hostname LPE2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
  hidekeys
encr aes
group 2
lifetime 28800
crypto isakmp key branch2 address 192.168.2.1
crypto map VPN 1 ipsec-isakmp
set peer 192.168.2.1
set pfs group2
match address 102
pseudowire-class L2
sequencing both
interface Loopback0
ip address 10.0.0.2 255.255.255.255
no ip address
shutdown
duplex half
ip address 192.168.2.2 255.255.255.0
negotiation auto
crypto map VPN
no ip address
negotiation auto
xconnect 10.0.0.1 104 pw-class L2
ip route 0.0.0.0 0.0.0.0 192.168.2.1
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
LPE2#
Test results:
LPE1#sh l2tun session
L2TP Session Information Total tunnels 1 sessions 1
                                 Vcid, Circuit
14681      44855      16488      104, Gi1/0           est    00:01:36 1
LPE1#sh ip access-lists
    10 permit ip host 10.0.0.1 host 10.0.0.2 (546 matches)
LHQ#ping 172.16.42.2                     <<< This is from the switch at the HQ
Sending 5, 100-byte ICMP Echos to 172.16.42.2, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 56/86/112 ms
LHQ#sh ip arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  172.16.42.1             -   ca05.01ac.001c  ARPA   GigabitEthernet1/0
Internet  172.16.42.2             0   ca06.1464.001c  ARPA   GigabitEthernet1/0
LHQ#
LHQ#sh cdp neighbors
LBR              Gig 1/0            150           R       7206VXR   Gig 1/0            << Branch Switch
LPE1             Gig 1/0            150           R       7206VXR   Gig 1/0
BR Router
LPE2#sh crypto ipsec sa peer 192.168.2.1 | i pkts
    #pkts encaps: 4, #pkts encrypt: 4, #pkts digest: 4               << Before I ping from the HQ CE
    #pkts decaps: 3, #pkts decrypt: 3, #pkts verify: 3
    #pkts encaps: 9, #pkts encrypt: 9, #pkts digest: 9             <<< After I ping from the HQ CE 5 packets increment
    #pkts decaps: 8, #pkts decrypt: 8, #pkts verify: 8
The hwics you used are a HWIC-1GIG, the cards I am using are HWIC-4ESW. The l2tpv3 tunnel comes up as previously mentioned and CDP comes across but traffic does not flow.  If you change the gig cards out to a 4esw or 9esw you should see what I am talking about. The gig hwics are full routed ports which is why they work. PM me and we can chat via email if you would like.
Rick,
sorry i missed that part from your original post. AFAIK HWIC-ESW's dont support port based L2TPV3 .  This is one of the limitations of ESW's. However, there is a workaround for this. That is to create an an SVI and use the x-connect on the SVI. I have labbed it for you. I used a 16ESW on a 3600 image. But this should apply for the 9ESW or 4ESW on the ISR as well.
TempPE1#sh l2tun session
%No active L2F tunnels
                                 Vcid, Circuit
17826      52340      40198      104, Vl104           est    00:01:08 3
%No active PPTP tunnels
TempPE1#sh run int vlan 104
Current configuration : 75 bytes
interface Vlan104
no ip address
end
TempPE1#sh run int fa0/1
Current configuration : 76 bytes
interface FastEthernet0/1
switchport access vlan 104
no cdp enable
end
TempPE1#
TempCE1#ping 172.16.42.2
Success rate is 80 percent (4/5), round-trip min/avg/max = 156/213/288 ms
TempCE1#
The other solution would be to go for Full routed HWIC-2FE etc.
Kishore
Xconnect is not supported on SVI on 15.1 3t code it is supported on physical interfaces.
