MPLS QoS with Uniform tunnel mode
ty.chan007
Hi, I am trying to test all mode of MPLS QoS tunnle mode like uniform,etc.
My diagram is as below:
CE01 --access--> ME4900 --trunk--> PE01 --ldp--> P01 --ldp--> P02 --ldp--> PE02 --access--> CE02
All traffic from CE01 are marked with DSCP AF31 an send to PE01. But PE01 can not see packet with AF31.
On ME4900, i just config access port and trunk port only. Nothing else were config on ME4900.
What should be the problem? or Does ME4900 reset DSCP value to 0 by default? if yes, how to fix it?
Hi Chanty
Can you try enabling the below command under ME4900 Gi1/7 interface and check
mls qos trust dscp
Varma
31 Replies 31
Vaibhava Varma
Level 4
Level 4
Hi Chan
Are you providing L3 VPN or L2 VPN services between CE01 and CE02..If its L2VPN then in my understanding we would not be able to see the DSCP marking at PE01 trunk interface towards ME4900.
If we send an AF31 packet from CE01 and don't alter anything in the MPLS Backbone and egress PE02 then on CE02 we should receive the same AF31 marking..
Varma
Hi Varma,
Thanks for reply.
I am doing L3 VPN and PE01 is not able to see AF31 when i sent the packet with AF31 from CE01.
I check on ME4900 and i got below result:
ME4900#sh qos
QoS is disabled globally
IP header DSCP rewrite is enabled
Is that could the problem that PE01 can not see AF31 as ME is rewriting the IP DSCP value?
chanty
Hi Chan
Can you check the cos-dscp mutation map for the default rewrite happening on the ME4900..On the Uplink trunk interface to PE01 are you trusting cos or dscp ?
On PE01 are you doing a dot1q subinterface config or VLAN SVI based config..Where did you check for the AF31 marking at PE01 on the L2 Trunk Interface or L3-dot1q subbinterface or L3 SVI ?
Note:Edited: And how about checking at CE02 whether the AF31 marking is received or not ?
Varma
Hi Varma,
1. I am not quite sure how to check cos-dscp mutation map. could you advise the command or doc? note: QoS is disable on ME4900 and there is not QoS config at all on ME4900. Eveything is kept at it default config.
2. I am doing subinterface as gateway for CE01. I am verifying the marking on subinterface with policy-map. I just create class to match with AF31 and apply to the interface.
Hi Chan
Please check for below commands on ME4900
show mls qos
show mls qos maps
Also please share the uplink trunk interface config for ME4900 to PE01
Varma
Hi Varma,
Below are the result:
interface GigabitEthernet1/7
description CONNECT-TO-PE-01
switchport trunk allowed vlan 76,88,89,94,101,1346,1370,1414,1503
switchport mode trunk
end
ME4900#sh mls qos
ME4900#sh mls qos maps
DSCP-TxQueue Mapping Table (dscp = d1d2)
d1 : d2  0  1  2  3  4  5  6  7  8  9
0 :    01 01 01 01 01 01 01 01 01 01
1 :    01 01 01 01 01 01 02 02 02 02
2 :    02 02 02 02 02 02 02 02 02 02
3 :    02 02 03 03 03 03 03 03 03 03
4 :    03 03 03 03 03 03 03 03 04 04
5 :    04 04 04 04 04 04 04 04 04 04
6 :    04 04 04 04
Policed DSCP Mapping Table (dscp = d1d2)
0 :    00 01 02 03 04 05 06 07 08 09
1 :    10 11 12 13 14 15 16 17 18 19
2 :    20 21 22 23 24 25 26 27 28 29
3 :    30 31 32 33 34 35 36 37 38 39
4 :    40 41 42 43 44 45 46 47 48 49
5 :    50 51 52 53 54 55 56 57 58 59
6 :    60 61 62 63
DSCP-CoS Mapping Table (dscp = d1d2)
0 :    00 00 00 00 00 00 00 00 01 01
2 :    02 02 02 02 03 03 03 03 03 03
3 :    03 03 04 04 04 04 04 04 04 04
4 :    05 05 05 05 05 05 05 05 06 06
5 :    06 06 06 06 06 06 07 07 07 07
6 :    07 07 07 07
CoS-DSCP Mapping Table
   CoS:   0  1  2  3  4  5  6  7
  DSCP:   0  8 16 24 32 40 48 56
chanty
Hi Chanty (sorry I was using wrong name till now..)
Since the MLS QoS is disabled globally everyhting should be passed unalteredly. Can you check and share for the trust state of the uplink interface Gi1/7 on ME4900 using
show mls qos interface Gi1/7
Varma
ME4900#sh mls qos int g1/7
Port QoS is enabled
Administrative Port Trust State: 'untrusted'
Operational Port Trust State: 'dscp'
Trust device: none
Default DSCP: 0 Default CoS: 0
Appliance trust: none
Tx-Queue   Bandwidth   ShapeRate   Priority   QueueSize
             (bps)       (bps)                (packets)
  1        250000000   disabled    N/A        2080
  2        250000000   disabled    N/A        2080
  3        250000000   disabled    normal     2080
  4        250000000   disabled    N/A        2080
ME4900#
Hi Chanty
mls qos trust dscp
Varma
Hi Varma,
Any performance impact when turn it on? How about access port, do i need to turn it on too?
chanty
Hi Chanty
If on the access port we are not doing any trust device or trust cisco-phone which is typical of an enterprise scenario then we would need to trust dscp on Access Link ( we can't use cos as its Access Port and no VLAN Info)
Please see below link for same which gives a nice explaination.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a0080883f9e.shtml
Regarding the impact of introducing this command in a production network, I can say from my personal experience and understanding this should not create any issue untill unless there is congestion as QoS is needed for avoiding congestion.Hope I make myself clear on this point..
Varma
Hi Varma,
Wow, many thanks for great advise and kindly help.
I will get back to you after i get the result.
chanty
Hi Varma,
Another strang output:
ME4900#sh mls ?
% Unrecognized command
ME4900#sh mls qos ?
ME4900#sh mls qos
It looks like mls command is not available but it work when i just enter it??
chanty
Hi Chanty
Can you check for the IOS Code of the ME4900 in the Cisco-Feature Navigator and see for MLS feature there..
I have see this a couple of times before same behaviour due to IOS..
Varma
