EoMPLS: Can I mix Dot1Q and port mode
jkeane100
Dear all
I am looking at a project that would involve migrating Ethernet traffic off a L2 network ( V Large) onto an MPLS network and I am looking to support the following configuration:
A customer has a firewall connected via Dot1Q to a PE. Can I configure one VC from that PE to a remote PE and have that PE also terminate on a Dot1Q configured port. Also the customer would need to have a connection to an other remote device that is connected via port mode.
Is it possible for the customer attachment port ( running dot1Q) to connect to both Dot1q and port mode endpoints
Any help greatly appreciated
John Keane
swaroop.potdar
Level 7
Level 7
John, you can do this interworking which is Vlan/Ethernet Interworking.
For configuration examples check this link out and also refer to the restrcitions.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_feature_guide09186a00801b2407.html
HTH-Cheers,
Swaroop
