EoMPLS Vlan Mode
mariusst
Community Member
I am trying to setup EoMPLS Vlan mode between an ASR9K and a 3825 that is connected as back to back PE's.
Although I managed to get the PW Tunnel up no data passed between the edge devices.
(7200Edge1)-----(ASR9K-PE1)----------(3800-PE2)-------(3800Edge2)
Please advise me on how to fix this.
These are the PE1 and PE2 configs
PE1
hostname ASR9K-PE1
interface GigabitEthernet0/0/0/17
cdp
mtu 1514
interface GigabitEthernet0/0/0/17.10 l2transport
encapsulation dot1q 10
l2vpn
pw-class test
  encapsulation mpls
   transport-mode vlan
xconnect group TEST
  p2p test
   neighbor 10.30.0.21 pw-id 7
    pw-class test
PE2
hostname 3800-PE2
pseudowire-class test
encapsulation mpls
interface GigabitEthernet0/1
mtu 1504
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
xconnect 10.30.0.16 7 pw-class test
PE1
sh l2vpn xconnect group TEST det
Thu Mar 10 12:37:41.910 UTC
Group TEST, XC test, state is up; Interworking none
  AC: GigabitEthernet0/0/0/17.10, state is up
    Type VLAN; Num Ranges: 1
    VLAN ranges: [10, 10]
    MTU 1504; XC ID 0x840002; interworking none
    Statistics:
      packets: received 1125, sent 1081
      bytes: received 101040, sent 95790
      drops: illegal VLAN 0, illegal length 0
  PW: neighbor 10.30.0.21, PW ID 7, state is up ( established )
    PW class test, XC ID 0x840002
    Encapsulation MPLS, protocol LDP
    PW type Ethernet VLAN, control word disabled, interworking none
    PW backup disable delay 0 sec
    Sequencing not set
      MPLS         Local                          Remote
      Label        16003                          16
      Group ID     0x4000540                      0x0
      Interface    GigabitEthernet0/0/0/17.10     unknown
      MTU          1504                           1504
      Control word disabled                       disabled
      PW type      Ethernet VLAN                  Ethernet VLAN
      VCCV CV type 0x2                            0x2
                   (LSP ping verification)        (LSP ping verification)
      VCCV CC type 0x6                            0x2
                   (router alert label)           (router alert label)
                   (TTL expiry)
    MIB cpwVcIndex: 0
    Create time: 10/03/2011 08:49:09 (03:48:31 ago)
    Last time status changed: 10/03/2011 10:15:38 (02:22:02 ago)
    Statistics:
      packets: received 1081, sent 1125
      bytes: received 95790, sent 101040
PE2
sh mpls l2transport vc detail
Local interface: Gi0/1.10 up, line protocol up, Eth VLAN 10 up
  Destination address: 10.30.0.16, VC ID: 7, VC status: up
    Output interface: Gi0/0, imposed label stack {16003}
    Preferred path: not configured
    Default path: active
    Next hop: 10.0.6.2
  Create time: 02:46:12, last status change time: 02:23:06
  Signaling protocol: LDP, peer 10.30.0.16:0 up
    MPLS VC labels: local 16, remote 16003
    Group ID: local 0, remote 67110208
    MTU: local 1504, remote 1504
    Remote interface description: GigabitEthernet0_0_0_17.10
  Sequencing: receive disabled, send disabled
  VC statistics:
    packet totals: receive 1047, send 1069
    byte totals:   receive 99846, send 118228
    packet drops:  receive 0, seq error 0, send 0
Laurent Aubert
ASR9k will negotiate VC Type 4 with the 3825. By default the AC on the 3825 will pop tag 10 and the PW will add a fake one (could be the same though) to respect VC Type 4.
On the ASR9k, the AC will do nothing by default so you will end with a packet with a double tag. You need to apply the rewrite ingress pop 1 symmetric command on the ASR9k sub-interface so you will have the same behavior than the 3825.
Laurent.
meperuma
Level 3
Level 3
Looks like your control plane is ok. Can you perform a pseudowire ping to make sure your forwarding plane is ok
Laurent Aubert
Laurent.
Thanks Laurent it works......
Glad to read that
Laurent.
