Error label ASR 901
1- I have an ASR 901 Router , and have been checking labels errors. I want to know how many labels an ASR 901 Router supports ?
2- On the other methods which you can use to avoid labels errors?
Aug 24 12:07:43.016: pstorm_compare_and_prog_label_in_bcm:2027: pstorm_bcm_prog_label failed f
or label= 2029
Aug 24 12:07:43.020: pstorm_bcm_prog_label:1251: l3_egress_create failed. Label: 34. Err: [0xF
FFFFFF2]. l3_egr_id 104128, gport 0x08002805, l3intf 14, bcm_flag 0x00000000, l3_egress.flags 0
x00000000
Aug 24 12:07:43.020: pstorm_compare_and_prog_label_in_bcm:2027: pstorm_bcm_prog_label failed f
or label= 34
Aug 24 12:07:43.020: pstorm_bcm_prog_label:1251: l3_egress_create failed. Label: 1290. Err: [0
xFFFFFFF2]. l3_egr_id 104128, gport 0x08002805, l3intf 14, bcm_flag 0x00000000, l3_egress.flags
0x00000000
or label= 1290
Aug 24 12:07:43.020: pstorm_bcm_prog_label:1251: l3_egress_create failed. Label: 394. Err: [0x
0x00000000
or label= 394
Renan Abreu
Take a look at this link, it may be helpful
https://supportforums.cisco.com/discussion/11941671/asr901-error-pstormbcmproglabel
