Ethernet over MPLS(ATOM)
Dear Friends
would like to seek your help to resolve one Ethernet ATOM case. The details are as follows.
Physical Connectivity:
PC1---Connected--->Vlan Switch--->Fas 4/0/0.1 of 7507-1(PE1)---> Connected to 7507-1 over Multil-Link PPP, with single E1 Link.
PC2---> Connected--->Vlan Switch Fas 1/0/0.1 of 7502-2(PE-2)---> Connected to 7507-1 over Multil-Link PPP, with single E1 Link.
Objective: To create L2 VPN to transport VLAN Traffic across PC1 & PC2, using Ethernet over MPLS.
„h In a way both 7507 i.e. PE1 & PE2 are connected back to back.
„h IP of PC1: 10.0.0.1/24 & PC2: 10.0.0.2/24
Configuration of PE1 & PE2:
PE1:
Interface Loopback 4
ip address a.b.c.d/32
mpls label protocol ldp
tag-switching tdp router-id Loopback4 force
Interface Fas 4/0/0.1---> This connects to PC1
encapsulation dot1q 10
mpls l2transport route p.q.r.s 100
Interface Multi-Link 2
ip address 192.168.0.1 255.255.255.252
no ip directed-broadcast
mpls label protocol both
tag-switching ip
no cdp enable
ppp authorization noauth
ppp multilink
multilink-group 1
PE2:
Interface Loopback 5
ip address p.q.r.s/32
tag-switching tdp router-id Loopback5 force
Interface Fas 4/0/0.1---> This connects to PC2
ip address 192.168.0.2 255.255.255.252
tag-switching ip
no cdp enable
ppp multilink
multilink-group 1
Observations:
„h While we see that Local & Remote End Tags are being exchanged, however Vc remains down(sh mpls l2transport vc) & Ping between PC1 & PC2 does not take place.
„h when we run debug, while every thing seems to be OK for MPLS establishment, however one line seems to be reporting some error:
At PE1 AToM SMGR [p.q.r.s, 100]: Imposition setup incomplete because unable to find a tunnel label
At PE2 AToM SMGR [a.b.c.d, 100]: Imposition setup incomplete because unable to find a tunnel label
It would your great help to share your advise & input to make this work.
Thanks & Regards
Shailendra
vkapoor5
Level 5
Level 5
I think the VC is declared down since the tunnel label is not known by the device as shown in the debug. Since your PE devices are connected back-to-back, the IGP label should be an implicit null in your case.
Dear All
Problem got resolved by inducting a "P" Router between two PE Routers. Yes, VC Label was getting exchanged, however there was no Tunnel Label being PE Router connected back to back (Label POPing).
Due to various connectivity need, we need to make this work with PE to PE, any suggestion how can we make this work.[we tried mpls explicit null too]
Shailendra
Try binding the remote Pe address's with static MPLS labels.
Pls chek the url.
http://www.cisco.com/en/US/customer/products/sw/iosswrel/ps1829/products_feature_guide09186a008010dd41.html
Thanks. I am sorry for late response.
We will try yr suggestion(it seems to be an alternate, like what we have static routing) and share the results.
Shailendra
