H-VPLS using MPLS in access
Dears,
I would like your assistance regarding below plz
How to map EoMPLS PW from U-PE to N-PE  to the VPLS network at N-PE
U-PE1 <----- MPLS ----->  N-PE2 <-------- VPLS Network -------> N-PE3
I believe xconnect vc @ U-PE should match vfi vpn id @ N-PE as below, correct ?
U-PE
interface gi1/0
ip add 10.0.0.1 255.255.255.0
xconnect 10.0.0.2 99 encapsulation mpls
N-PE2
l2 vfi test manual
vpn id 99
neighbor 3.3.3.3 encapsulation mpls
neighbor 4.4.4.4 encapsulation mpls
Many Thanks
BR,
Sherif Ismail
5 Replies 5
maayre
Hi Sherif,
I'm not sure that the ID has to match, I believe you are missing a neighbor statement on the N-PE2 towards the U-PE;
     l2 vfi test manual
     vpn id 99
     neighbor 10.0.0.1 99 enc mpls
It seems a little odd that the U-PE xconnect IP is to a destination inside a subnet on the same interface, maybe you meant;
     int gi1/0
     xconnect 10.0.0.2 99 enc mpls
     int gi1/1
     mpls ip
The only reference I could find was from another different thread on this forum which referenced this;
http://www.cisco.com/en/US/docs/ios/zz_trash/mp_hvpls_npe_red.html#wp1056907
Thanks Matthew
Maybe thats why it was not working .... I will try above & let you know
Many Thanks
BR,
Sherif Ismail
Remember,
If you want to segment traffic.  Use the xconnect on the SVI.
example
Vlan100 - customer A
Vlan 200 - customer B
l2 vfi 99 manual
vpn id 99
neighbor 1.1.1.1 encapsulation mpls
l2 vfi 98 manual
vpn id 98
neighbor 2.2.2.2 encapsulation mpls
interface vlan100
ip address 10.1.1.1 255.255.255.0
xconnect vfi 99
interface vlan200
ip address 10.2.2.1 255.255.255.0
xconnect vfi 98
This way you can segment traffic comming in on one port and forward to different destination.
Jude
Thanks Jude for your reply
Your configuration works well with QinQ H-VPLS however I am asking about MPLS H-VPLS
I still didnt try Matthew suggestion
Will let you know once I tried it
Sherif Ismail
I knew that.  Just wanted to throw in an additional scenerio.
Jude
