How to configure IS-IS with VRF ?-->( In router mode, vrf <vrf_name> is not working. In globle mode, router isis <tag> vrf <vrf_name> is not working
shyam4050
Hi All,
I am trying below set up in gns3 with Cisco IOS Software, 2600 Software (C2691-ADVIPSERVICESK9-M), Version 12.4(15)T6, RELEASE SOFTWARE (fc2).
PFB :
R2#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R2(config)#do sh ip vrf
  Name                             Default RD          Interfaces
  CSC                              100:1               Fa0/0
R2(config)#do sh run | sec vrf
ip vrf CSC
rd 100:1
route-target export 100:1
route-target import 100:1
ip vrf forwarding CSC
R2(config)#do sh run | sec isis
ip router isis 1
router isis 1
net 49.0001.0000.0002.00
R2(config)#do sh run int f0/0
Building configuration...
Current configuration : 134 bytes
interface FastEthernet0/0
ip address 10.1.2.2 255.255.255.0
ip router isis 1
duplex auto
speed auto
end
R2(config)#router isis 1 ?
  <cr>
R2(config)#router isis 1 vrf?
% Unrecognized command
R2(config-router)#v?
R2(config-router)#v
Peter Paluch
Hi shyam,
Unfortunately, these IOSes do not support per-VRF IS-IS instances. There may be IOS images for 7200 router series that will support this feature (IOS 15.x).
You might want to consider trying VIRL (http://virl.cisco.com) - it is equipped with very recent IOS versions and will provide you with most features found only on recent platforms.
Best regards,
Peter
Hi Peter,
Thanks.
I will try differet IOS version for it.
BR
shyam
Vinit Jain
Hello Shyam
Please refer to the below config for VRF aware isis:
ip vrf ABC
rd 1:1
route-target export 1:1
route-target import 1:1
interface GigabitEthernet0/2
ip vrf forwarding ABC
ip address 10.1.21.1 255.255.255.252
ip router isis
duplex auto
speed auto
media-type rj45
interface Loopback10
ip address 192.168.100.100 255.255.255.255
ip router isis
router isis
vrf ABC
net 47.0000.0000.0001.00
is-type level-1
metric-style wide
R1#show isis nei
Tag null:
System Id Type Interface IP Address State Holdtime Circuit Id
R3 L1 Gi0/2 10.1.21.2 UP 24 R1.01
R1#
Hope this helps.
Vinit
--Vinit
Just forgot to mention, this was tried on 15.x release. You may try similar configuration method on the IOS that you are running and see if that helps.
Vinit
--Vinit
