날짜: 02-27-2006 10:43 PM
날짜: 02-28-2006 02:07 AM
The typical way to do this is to create a management VRF. You would then inject routes for the management segments into each customer VRF (they would, of course, have to be non-conflicting with customer space, or you could use public address space). Then, configure a loopback address on each CE router and give it an address out of the management space. When exporting this route into MP-BGP, give it a route-target that is subsequently imported by the management VRF.
That way, the mangement VRF can be used to poll the loopbacks of all CE routers....
An example:
CE1:
-- Loopback: 10.1.1.1/32
-- Customer routes: 192.168.1.0/24
PE1:
-- exports CE1 loopback with the Mgmt RT
-- imports customer routes with the Cust RT
-- import routes with the MgmtSegment RT
On PE that is connected to management segmet:
-- import all routes bearing the Mgmt RT
-- export the management segment route with the MgmtSegment RT
Hope that helps - pls rate the post if it does.
Paresh
날짜: 03-01-2006 04:15 AM
Thanks for the reply.
So to inject the routes for management into customers vrf's, would I use a route-target import or an import map?
MB
날짜: 03-01-2006 04:41 AM
you could use an export map. The config would look like this:
ip vrf NMS
rd 65000:161
export map NMS
route-target import 65000:162
ip vrf Customer
rd 65000:10000
route-target export 65000:10000
route-target import 65000:10000
route-target import 65000:161
export map ManagedCE
route-map NMS permit 10
match ip address prefix-list 20
set extcommunity 65000:161
route-map ManagedCE permit 10
match ip address 30
set extcommunity rt 65000:162 additive
ip prefix-list 20 seq 5 permit 10.161.0.0/24
access-list 30 permit host 192.168.1.100
This assumes, that the CE to be managed has a Loopback IP of 192.168.1.100/32 and is included in PE-CE routing. The admin LAN with NMS workstations is 10.161.0.0/24 in my example.
As a last remark: the VRF NMS needs not to be configured on every PE.
Hope this helps! PLease rate all posts.
Regards, Martin
날짜: 03-27-2006 04:20 PM
Thanks Martin - Works nicely!
You stated that VRF NMS needs not to be configured on every PE - How would I add an interface to vrf NMS if it doesn't exist on the PE?
Example:
(On PE without NMS configured):
#interface Loopback11
(config-if)# description NMS Test Interface
(config-if)# ip vrf forwarding NMS
% VRF NMS not configured.
MB
날짜: 03-27-2006 04:56 PM
What Martin meant was that you don't need the NMS VRF defined on PEs that do not have any interfaces in the NMS VRF but you could still export routes targetted towards the VRF NMS on those PEs. In the example you posted, you do indeed have to define the NMS VRF.
Paresh
날짜: 03-27-2006 04:59 PM
Understood - Thanks for the clarification.
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
