How to push traffic to SR Policy ??
samarjit dutta
Intention:
Forwarding traffic destined for vrf A & traffic destined for R6 l01(66.66.66.66/32) based on SRTE explicit path
My SR Policy on head-end router is UP, receiving prefix from remote PE with proper next-hop and color ext community
I am new to SRTE and trying to explore it.
my understanding traffic should automatically choose the SRTE policy if the next-hop matches the policy endpoint and prefix match the color.
but in my case it interested traffic not using the SRTE path.
Am I missing something ?
R6 configuration:(End Point)
Setting color for interested traffic one vpnv4 route and one ipv4 route
extcommunity-set opaque RED
end-set
route-policy SETCOLOR
  if extcommunity rt matches-any (100:20) then
    set extcommunity color RED
  endif
  if destination in (66.66.66.66/32) then
  endif
  pass
end-policy
router bgp 100
 address-family ipv4 unicast
  network 66.66.66.66/32
 address-family vpnv4 unicast
 neighbor 1.1.1.1
  remote-as 100
  update-source Loopback0
   route-policy SETCOLOR out
Head end configuration on R1
ipv4 unnumbered mpls traffic-eng Loopback0
segment-routing
 global-block 16600 16699
 traffic-eng
  segment-list SLIST1
   index 10 address ipv4 2.2.2.2
   index 20 address ipv4 4.4.4.4
   index 30 address ipv4 3.3.3.3
   index 40 address ipv4 5.5.5.5
   index 50 address ipv4 6.6.6.6
  policy 100
   binding-sid mpls 111
   color 10 end-point ipv4 6.6.6.6
   candidate-paths
    preference 100
     explicit segment-list SLIST1
Tunnel is UP
RP/0/0/CPU0:R-1#show mpls forwarding tunnels detail
Wed Sep 11 00:02:19.600 UTC
Tunnel        Outgoing    Outgoing     Next Hop        Bytes
Name          Label       Interface                    Switched
100          (SR) 16204       Gi0/0/0/0    10.1.2.2        0
     Updated: Sep 10 23:15:57.840
     Version: 699, Priority: 2
     Label Stack (Top -> Bottom): { 16204 16403 16305 16506 }
     NHID: 0x0, Encap-ID: N/A, Path idx: 0, Backup path idx: 0, Weight: 0
     MAC/Encaps: 14/30, MTU: 1500
     Outgoing Interface: GigabitEthernet0/0/0/0 (ifhandle 0x00000040)
     Packets Switched: 0
  Interface:
    Name: 100 (ifhandle 0x00000050)
    Local Label: 24005, Forwarding Class: 0, Weight: 0
    Packets/Bytes Switched: 0/0
RP/0/0/CPU0:R-1#
RP/0/0/CPU0:R-1#show segment-routing traffic-eng policy detail
Wed Sep 11 00:04:17.602 UTC
SR-TE policy database
Name: 100 (Color: 10, End-point: 6.6.6.6)
  Status:
    Admin: up  Operational: up for 00:48:19 (since Sep 10 23:15:57.711)
  Candidate-paths:
    Preference 100:
      Explicit: segment-list SLIST1 (active)
        Weight: 0, Metric Type: IGP
          16602 [Prefix-SID, 2.2.2.2]
          16204 [Prefix-SID, 4.4.4.4]
          16403 [Prefix-SID, 3.3.3.3]
          16305 [Prefix-SID, 5.5.5.5]
          16506 [Prefix-SID, 6.6.6.6]
  Attributes:
    Binding SID: 111
      Allocation mode: explicit
      State: Programmed
      Policy selected: yes
    Forward Class: 0
Head end receving BGP prefixes with proper colors
RP/0/0/CPU0:R-1#show bgp vpnv4 un vrf A 20.200.200.1
Wed Sep 11 00:03:19.856 UTC
BGP routing table entry for 20.200.200.0/24, Route Distinguisher: 100:20
Versions:
  Process           bRIB/RIB  SendTblVer
  Speaker                932         932
Last Modified: Sep 10 23:57:54.918 for 00:05:25
Paths: (1 available, best #1)
  Not advertised to any peer
  Path #1: Received by speaker 0
  Local
    6.6.6.6 (metric 40) from 6.6.6.6 (6.6.6.6)
      Received Label 24006
      Origin incomplete, metric 2, localpref 100, valid, internal, best, group-best, import-candidate, imported
      Received Path ID 0, Local Path ID 1, version 932
      Extended community: Color:10 OSPF route-type:0:1:0x0 OSPF router-id:20.0.2.1 RT:100:20
      Source AFI: VPNv4 Unicast, Source VRF: A, Source Route Distinguisher: 100:20
RP/0/0/CPU0:R-1#
RP/0/0/CPU0:R-1#show bgp ipv4 unicast 66.66.66.66
Wed Sep 11 00:07:30.079 UTC
BGP routing table entry for 66.66.66.66/32
Versions:
  Speaker                112         112
Last Modified: Sep 10 23:57:54.918 for 00:09:35
  Local
      Origin IGP, metric 0, localpref 100, valid, internal, best, group-best
      Received Path ID 0, Local Path ID 1, version 112
RP/0/0/CPU0:R-1#
But traffic is using IGP PATH
RP/0/0/CPU0:R-1#traceroute vrf A 20.200.200.1
Wed Sep 11 00:12:15.379 UTC
Tracing the route to 20.200.200.1
 1  10.1.2.2 [MPLS: Labels 16206/24006 Exp 0] 79 msec  19 msec  19 msec
 2  10.2.3.2 [MPLS: Labels 16306/24006 Exp 0] 19 msec  19 msec  19 msec
 3  10.3.6.2 [MPLS: Label 24006 Exp 0] 19 msec  19 msec  19 msec
 4  20.0.2.2 19 msec  *  9 msec
RP/0/0/CPU0:R-1#traceroute 66.66.66.66
Wed Sep 11 00:12:41.347 UTC
Tracing the route to 66.66.66.66
 1  10.1.4.2 [MPLS: Label 16406 Exp 0] 0 msec  0 msec  0 msec
 2  10.3.4.1 [MPLS: Label 16306 Exp 0] 0 msec  0 msec  0 msec
 3  10.3.6.2 0 msec  *  0 msec
RP/0/0/CPU0:R-1#
Harold Ritter
Hi Samarjit,
What version of XR are you using on R-1?
I am also using 6.4.2.
I saw your reply on the other discussion ...
https://community.cisco.com/t5/mpls/mpls-l3vpn-over-sr-te-policy/m-p/3777357
Need to try it on 6.5.2 or higher.
thanks for looking into it.
You are very welcome. I am glad I could help.
