How to verify communities since and from peers?
mbonilla
Hello folks, I have this typical scenario:
               |CE1|-----------|PE1|-----------|P|----------|PE2|-----------|CE2|
           1.1.1.1/32       2.2.2.2/32     3.3.3.3/32 4.4.4.4/32     5.5.5.5/32
        Lo0 10.34.154.90
The PE-CE protocol of choice is BGP, and the customer wants to add whatever community to prefixes as they want without the intervention of the provider. I setup the send-community both VPNv4 statement in the PE routers, but I have not found a good command can help me verify the community added by CEs to prefixes.
Using the command in PE2:
show ip bgp vpnv4 all <prefix> , show the regular community using by the RT, but not the added by the CE with additive statement.
PE1#sh ip bgp vpnv4 all 10.34.154.90
BGP routing table entry for 22364:21300:10.34.154.90/32, version 44605017
Paths: (1 available, best #1, table VRF1)
Advertised to update-groups:
     1         2         596
64852
   CE2 from CE2 (10.43.255.255)
     Origin incomplete, metric 0, localpref 100, valid, external, best
     Community: 200 14549214
     Extended Community: RT:22364:21300
     mpls labels in/out 918/nolabel
What command can show me the total of the extend communities?
Also how can I change the peer: 10.25.234.14 (CE2) from the point of view of this command to P peer?
Thanks in advanced
Giuseppe Larosa
Hello Mbonilla,
PE-CE protocol is EBGP but it is a standard session so the CE can only add standard BGP communities
the second line refers to RT extended community the first line refers to standard community.
It is likely that the community was set by CE router I see that the value is expressed in the default format.
In order to see more readable community ( like ASN:value)  values you need the command
config t
ip bgp-community new-format
see
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_bgp/command/bgp-c1.html#GUID-D2961543-7CC3-4AB0-8CD7-4DC0B47F32E1
after this the router will show communities values like 65000:2345, instead of a 32 bit unsigned integer that we poor human beings cannot understand!
Hope to help
Giuseppe
