Implementing MPLS
jpvelaz
I am cutting a frame-relay with ISDN backup Network over to MPLS with DSL Backup - I want to use OSPF on the MPLS and EIGRP over DSL; I have a mixture of routers 1750, 1751, & 1760. I have been doing my DD but was wondering if anyone here has done this and has any tips or a good place to some more research and or a good place to find a config builder?
a.alekseev
Level 7
Level 7
I'm so sorry but routers 1750, 1751, & 1760 do not support mpls.
WBR,
Aleksey
can you recommend a router that will support both MPLS and DSL?
You can try the ciso 1800,2800 or the 3800 series routers...depending upon your budget .You can be sure to get the best BANG!!! for your $$$$.
