Import specific routes from specific vrfs - need equivalent of route-map and
Jeffrey Wampler
We have a service network that hosts servers to be shared with multiple customers, and we provide full MPLS networks for those customers. So within each customer VRF we need to be able to allow customers to advertise any route to our PEs, so they can transport traffic across their VRF to any destination PE.
Say CUST1 (RT 1:1) has been assigned 172.16.0.0/24 as their client to our service.
Say CUST2 (RT 2:1) has been assigned 172.16.1.0/24 as their client to our service.
So far easy import RT 1:1 and 2:2 with a map (filter/prefix-list) allowing only 172.16.0.0/24 and 172.16.1.0/24.
ip vrf SP
 rd 208.83.11.4:100
 import map SP-IMPORT
 route-target export 100:1
 route-target import 1:1
 route-target import 2:1
ip prefix-list CUST1 seq 100 permit 172.16.0.0/24
ip prefix-list CUST2 seq 100 permit 172.16.1.0/24
route-map SP-IMPORT permit 100
match ip address prefix-list CUST1
route-map SP-IMPORT permit 200
match ip address prefix-list CUST2
Now say CUST1 has 172.16.1.0/24 in their vrf used for another purpose, so we want to import 172.16.1.0/24 but NOT from CUST1. This is where it all breaks down.
We tried:
ip vrf SP
 rd 208.83.11.4:100
ip extcommunity-list standard CUST1 permit rt 1:1
ip extcommunity-list standard CUST2 permit rt 2:1
match extcommunity CUST1
match extcommunity CUST2
BUT.... since the matches are address AND extcommunity the route-map MATCH becomes an OR so if either match the import is a success, so we get 172.16.1.0/24 from CUST1 when we want it from CUST2.
Cannot figure out even with continue how to select routes from a specific VRF/RT ONLY any help would be greatly appreciated.
JW
Bharat Negi
Hi JW
Try to filter 172.16.1.0/24 using a export-map when CUST1 is exporting out of VRF towards MPLS backbone.
Or use an export-map with ACL matching 172.16.0.0/24 and set a different RT (say 1:4) when CUST1 is exporting out of VRF towards MPLS backbone and then import 1:4 at vrf SP.
Bharat
Yahia CHARIF
Hi Jeffrey,
I don't think that the AND close becomes OR in your route-map. I tested that and it works fine.
If several match commands are present in a clause, all must succeed for a given route in order for that route to match the clause (in other words, the logical AND algorithm is applied for multiple match commands).
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/49111-route-map-bestp.html#basics
Your configuration is correct:
ip vrf SP
  rd 208.83.11.4:100
