Inter AS VPN and Netflow Problem
rabeder
Level 5
Level 5
Hi, i have a bgp router(7206), which acts as mpls-pe router in direction to our mpls cloud and as a bgp border router to a different providers mpls cloud.
as described in cisco doku, there is no labeldistribution between the bgp as borderrouter.
but:
if the 7206 gets a packet from a customer in my mpls cloud, the packet has a vrf label and a transportlabel.
when this paket has to go to the other as (to the mpls cloud of the different provider), the interface (gig0/2.541)drops one label (the transport) and forwards the paket with the vrf label to the inter as link.
we have a crannog tool which analysis our flow.
if i look at gig0/2.541 i have very, very strange pakets (ip- source-adr) which are not possible on this link.
i think the problem is that netflow does not know that there is a vrf label in this paket and so it thinks the vrf label belongs to the adresss.
any idea ??
mplsrbgope02#sh ip cache flow | in 58.17
Gi0/2.190 61.17.58.179 AT3/0.78 10.48.38.20 92 0000 0000 1
Gi0/2.190 0.0.64.0 AT3/0.77 58.17.229.17 10 0000 0000 1
Gi0/2.190 58.17.208.13 Gi0/2.541 10.18.120.102 01 0000 0000 1
Gi0/2.190 58.17.208.14 Gi0/2.541 10.18.120.102 00 0000 0000 1
Gi0/2.190 58.17.144.171 Gi0/2.541 10.18.120.97 67 0000 0000 1
Gi0/1.194 10.18.120.225 AT3/0.188 10.20.58.17 01 0000 0800 1
AT3/0.188 10.20.58.17 Gi0/1.194 10.18.120.225 01 0000 0000 1
Gi0/2.190 58.17.161.218 Gi0/2.541 10.18.120.97 B0 0000 0000 1
mplsrbgope02#
oettls
Level 3
Level 3
just to be sure:
your topology is the Inter-AS Option B of RFC2547bis ?
What code do you run on your gateway router ? There is a MPLS-aware Netflow feature which also has some restrictions. Perhaps you can check:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123t/123t_8/gt_mnf.htm
you'll have to use V9 exports in order to implement that feature ...
hth,
Stefan
hi,
thanks for answer.
i am using inter-as mpls vpn as described in:
http://www.cisco.com/en/US/tech/tk436/tk428/technologies_configuration_example09186a0080094472.shtml
my 7206 uses ios:
System image file is "disk2:c7200-js-mz.123-15a.bin"
i have netlow version 9 enabeld, but i dont want to see labels in netflow - i only want that the router or netflow "knows" that ther is a label (vrf-label) on the link to the other as - so that netflow has the right source ip address.
here is the relavant konfig:
the link to MY mpls-cloud:
interface GigabitEthernet0/2.190
encapsulation dot1Q 190
ip address 172.16.24.93 255.255.255.224
ip flow ingress
mpls label protocol ldp
tag-switching mtu 1512
tag-switching ip
and here is the konfig of the link to the other providers as:
interface GigabitEthernet0/2.541
bandwidth 96000
encapsulation dot1Q 541
ip address 172.20.7.49 255.255.255.252
ip flow ingress
mpls netflow egress
rabeder
Level 5
Level 5
hi,
i found the reason for the wrong ip-addresses in the netflow output:
it was the "mpls netflow egress" command on the gig0/2.541 interface !!
